Abstract : Emerging applications for the Internet of Things (IoT) are complex programs which are composed of multiple modules (or services). For scalability, reliability and performance, modular applications are distributed on infrastructures that support utility computing (e.g., Cloud, Fog). In order to simply operate such infrastructures, an Infrastructure-as-a-Service (IaaS) manager is required. OpenStack is the de-facto open-source solution to address the IaaS level of the Cloud paradigm. However, OpenStack is itself a large modular application composed of more than 150 modules that make it hard to deploy manually. To fully understand how IaaSes are deployed today, we propose in this paper an overall model of the application deployment process which describes each step with their interactions. This model then serves as the basis to analyse five different deployment tools used to deploy OpenStack in production: Kolla, Enos, Juju, Kubernetes, and TripleO. Finally, a comparison is provided and the results are discussed to extend this analysis.
