Scaffolding a Skeleton - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
The goal of this paper is to construct a quadrilateral mesh around a one-dimensional skeleton that is as coarse as possible, the " scaffold ". A skeleton allows one to quickly describe a shape, in particular a complex shape of high genus. The constructed scaffold is then a potential support for the surface representation: it provides a topology for the mesh, a domain for parametric representation (a quad mesh is ideal for tensor product splines) or, together with the skeleton, a grid support on which to project an implicit surface that is naturally defined by the skeleton through convolution. We provide a constructive algorithm to derive a quad-mesh scaffold with topologically regular cross-sections (which are also quads), and no T-junctions. We show that this construction is optimal in the sense that no coarser quad mesh with topologically regular cross-sections may be constructed. Finally, we apply an existing rotation minimization algorithm along the skeleton branches, which produces a mesh with a natural edge flow along the shape.
SkeletonScaffold.pdf (2.54 Mo) Télécharger le fichier
hal-01532765 , version 1 (03-06-2017)
hal-01532765 , version 2 (18-06-2017)
  • HAL Id : hal-01532765 , version 1
Athina Panotopoulou, Kathrin Welker, Elissa Ross, Evelyne Hubert, Géraldine Morin. Scaffolding a Skeleton. 2017. ⟨hal-01532765v1⟩
676 Consultations
1133 Téléchargements
