Conference papers
Debugging of Concurrent Systems using Counterexample Analysis
Gianluca Barbon 1 Vincent Leroy 2 Gwen Salaün 1
1 CONVECS - Construction of verified concurrent systems
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
2 SLIDE - ScaLable Information Discovery and Exploitation [Grenoble]
Abstract : Model checking is an established technique for automatically verifying that a model satisfies a given temporal property. When the model violates the property, the model checker returns a counterexample , which is a sequence of actions leading to a state where the property is not satisfied. Understanding this counterexample for debugging the specification is a complicated task for several reasons: (i) the counterexample can contain hundreds of actions, (ii) the debugging task is mostly achieved manually, and (iii) the counterexample does not give any clue on the state of the system (e.g., parallelism or data expressions) when the error occurs. This paper presents a new approach that improves the usability of model checking by simplifying the comprehension of counterexamples. Our solution aims at keeping only actions in counterexamples that are relevant for debugging purposes. To do so, we first extract in the model all the counterexamples. Second, we define an analysis algorithm that identifies actions that make the behaviour skip from incorrect to correct behaviours, making these actions relevant from a debugging perspective. Our approach is fully automated by a tool that we implemented and applied on real-world case studies from various application areas for evaluation purposes.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01533401
Contributor : Gianluca Barbon Connect in order to contact the contributor
Submitted on : Friday, August 4, 2017 - 4:57:45 PM
Last modification on : Thursday, October 21, 2021 - 3:52:20 AM
File
fsen17_rev.pdf
Identifiers
Citation
Gianluca Barbon, Vincent Leroy, Gwen Salaün. Debugging of Concurrent Systems using Counterexample Analysis. 7th International Conference on Fundamentals of Software Engineering (FSEN), Apr 2017, Tehran, Iran. pp.20-34, ⟨10.1007/978-3-319-68972-2_2⟩. ⟨hal-01533401v2⟩
Share
Metrics
Record views
574
Files downloads
914
