Abstract : In this article is discussed novel method of the so-called complex networks dynamics and its visualization by means of so called coupled map lattices method. The main aim of this research is to demonstrate possibility to visualize complex network dynamics by means of the same method, that is used spatiotemporal chaos modeling. It is suggested here to use coupled map lattices system to simulate complex network so that each site is equal to one vertex of complex network. Interaction between network vertices is in coupled map lattices equal to the strength of mutual influence between system sites. Also another results from previous experiments, where dynamics of evolutionary algorithms has been converted to complex network and consequently to CML, are mentioned at the end. All results has been properly visualized and explained.
https://hal.inria.fr/hal-01533583 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, June 6, 2017 - 3:52:26 PM Last modification on : Saturday, June 1, 2019 - 11:34:02 AM Long-term archiving on: : Thursday, September 7, 2017 - 1:21:52 PM
Ivan Zelinka, Donald Davendra, Lenka Skanderova. Visualization of Complex Networks Dynamics: Case Study. Networking Workshops (NETWORKING), May 2012, Prague, Czech Republic. pp.145-150, ⟨10.1007/978-3-642-30039-4_19⟩. ⟨hal-01533583⟩
