How to Break EAP-MD5 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fanbao Liu
  • Fonction : Auteur
  • PersonId : 1009960
We propose an efficient attack to recover the passwords, used to authenticate the peer by EAP-MD5, in the IEEE 802.1X network. First, we recover the length of the used password through a method called length recovery attack by on-line queries. Second, we crack the known length password using a rainbow table pre-computed with a fixed challenge, which can be done efficiently with great probability through off-line computations. This kind of attack can also be implemented successfully even if the underlying hash function MD5 is replaced with SHA-1 or even SHA-512.
978-3-642-30955-7_6_Chapter.pdf (350.92 Ko) Télécharger le fichier
hal-01534313 , version 1 (07-06-2017)
Paternité
Fanbao Liu, Tao Xie. How to Break EAP-MD5. 6th International Workshop on Information Security Theory and Practice (WISTP), Jun 2012, Egham, United Kingdom. pp.49-57, ⟨10.1007/978-3-642-30955-7_6⟩. ⟨hal-01534313⟩
97 Consultations
2473 Téléchargements
