A Formally Verified Interpreter for a Shell-like Programming Language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The shell language is widely used for various system administration tasks on UNIX machines, as for instance as part of the installation process of software packages in FOSS distributions. Our mid-term goal is to analyze these scripts as part of an ongoing effort to use formal methods for the quality assurance of software distributions, to prove their correctness, or to pinpoint bugs. However, the syntax and semantics of POSIX shell are particularly treacherous. We propose a new language called CoLiS which, on the one hand, has well-defined static semantics and avoids some of the pitfalls of the shell, and, on the other hand, is close enough to the shell to be the target of an automated translation of the scripts in our corpus. The language has been designed so that it will be possible to compile automatically a large number of shell scripts into the CoLiS language. We formally define its syntax and semantics in Why3, define an interpreter for the language in the WhyML programming language, and present an automated proof in the Why3 proof environment of soundness and completeness of our interpreter with respect to the formal semantics.
jeannerod-marche-treinen-vstte17.pdf (331.05 Ko) Télécharger le fichier
hal-01534747 , version 1 (08-06-2017)
  • HAL Id : hal-01534747 , version 1
Nicolas Jeannerod, Claude Marché, Ralf Treinen. A Formally Verified Interpreter for a Shell-like Programming Language. VSTTE 2017 - 9th Working Conference on Verified Software: Theories, Tools, and Experiments, Jul 2017, Heidelberg, Germany. ⟨hal-01534747⟩
630 Consultations
16080 Téléchargements
