Security Limitations of Using Secret Sharing for Data Outsourcing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jonathan L. Dautrich
  • Fonction : Auteur
  • PersonId : 1010027
Chinya V. Ravishankar
  • Fonction : Auteur
  • PersonId : 1010028
Three recently proposed schemes use secret sharing to support privacy-preserving data outsourcing. Each secret in the database is split into n shares, which are distributed to independent data servers. A trusted client can use any k shares to reconstruct the secret. These schemes claim to offer security even when k or more servers collude, as long as certain information such as the finite field prime is known only to the client. We present a concrete attack that refutes this claim by demonstrating that security is lost in all three schemes when k or more servers collude. Our attack runs on commodity hardware and recovers a 8192-bit prime and all secret values in less than an hour for k = 8.
978-3-642-31540-4_12_Chapter.pdf (489.16 Ko) Télécharger le fichier
hal-01534766 , version 1 (08-06-2017)
Paternité
Jonathan L. Dautrich, Chinya V. Ravishankar. Security Limitations of Using Secret Sharing for Data Outsourcing. 26th Conference on Data and Applications Security and Privacy (DBSec), Jul 2012, Paris, France. pp.145-160, ⟨10.1007/978-3-642-31540-4_12⟩. ⟨hal-01534766⟩
76 Consultations
93 Téléchargements
