Catalyst Acceleration for Gradient-Based Non-Convex Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We introduce a generic scheme to solve nonconvex optimization problems using gradient-based algorithms originally designed for minimizing convex functions. When the objective is convex, the proposed approach enjoys the same properties as the Catalyst approach of Lin et al, 2015. When the objective is nonconvex, it achieves the best known convergence rate to stationary points for first-order methods. Specifically, the proposed algorithm does not require knowledge about the convexity of the objective; yet, it obtains an overall worst-case efficiency of O(ε−2) and, if the function is convex, the complexity reduces to the near-optimal rate O(ε −2/3). We conclude the paper by showing promising experimental results obtained by applying the proposed approach to SVRG and SAGA for sparse matrix factorization and for learning neural networks.
arxiv_v2.pdf (766.54 Ko) Télécharger le fichier
hal-01536017 , version 1 (09-06-2017)
  • HAL Id : hal-01536017 , version 1
Courtney Paquette, Hongzhou Lin, Dmitriy Drusvyatskiy, Julien Mairal, Zaid Harchaoui. Catalyst Acceleration for Gradient-Based Non-Convex Optimization. 2017. ⟨hal-01536017⟩
488 Consultations
272 Téléchargements
