Control and evaluation of a 2-D Multimodal Controlled-Friction Display - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The multimodal control of a 2D controlled-Friction Device is presented. We use the Vector control method because the phase and amplitude of two vibration modes at a same frequency can be precisely set. The closed loop response time of 10 ms is achieved. The device is then associated with a finger position sensor. The algorithm of the multimodal approach is then tested. In spite of the inevitable limitations of the system-saturation of amplifiers, low sampling frequency of the sensor-low friction could be imposed under a finger while a high friction was imposed on a predetermined position. This confirms the validity of the modal approach to create multi touch interactions.
Ghenna_WH17.pdf (4.13 Mo) Télécharger le fichier
hal-01538340 , version 1 (13-06-2017)
  • HAL Id : hal-01538340 , version 1
Sofiane Ghenna, Christophe Giraud-Audine, Frédéric Giraud, Michel Amberg, Betty Lemaire-Semail. Control and evaluation of a 2-D Multimodal Controlled-Friction Display. IEEE World Haptics 2017, Jun 2017, Fürstenfeldbruck (Munich), Germany. ⟨hal-01538340⟩
459 Consultations
179 Téléchargements
