Abstract : We explore the sequential decision-making problem where the goal is to estimate a number of linear models uniformly well, given a shared budget of random contexts independently sampled from a known distribution. For each incoming context, the decision-maker selects one of the linear models and receives an observation that is corrupted by the unknown noise level of that model. We present Trace-UCB, an adaptive allocation algorithm that learns the models' noise levels while balancing contexts accordingly across them, and prove bounds for its simple regret in both expectation and high-probability. We extend the algorithm and its bounds to the high dimensional setting , where the number of linear models times the dimension of the contexts is more than the total budget of samples. Simulations with real data suggest that Trace-UCB is remarkably robust , outperforming a number of baselines even when its assumptions are violated.
