Thus, the approximation ratio of Algorithm 7 is 1 /3, since optimal densest k-subgraphs are built for G[V 1 ], G[V 2 ] and B, and one of them contains at least one third of the optimum number of edges In Line 1, a minimum vertex cover can be computed in O * (1.2738 ? ) as in [18]. As |V 1 and V \ V * is an independent set. Finally, as B is a bipartite graph, Proof. By construction E = E(V 1 ) ? E(V 2 ) ? E Line 3 runs in O * Line 4, use Generic since |V 2 ? V * | = ? Line 5 runs in O * (2 min{|V 1 |,|V 2 } ) = O * (2 |V 1 | ) = O * ,
Finding dense subgraphs with size bounds, WAW'09, pp.25-36, 2009. ,
Polynomial Time Approximation Schemes for Dense Instances of NP-Hard Problems, Journal of Computer and System Sciences, vol.58, issue.1, pp.193-210, 1999. ,
DOI : 10.1006/jcss.1998.1605
Complexity of finding dense subgraphs, Discrete Applied Mathematics, vol.121, issue.1-3, pp.15-26, 2002. ,
DOI : 10.1016/S0166-218X(01)00243-8
URL : http://doi.org/10.1016/s0166-218x(01)00243-8
Constant factor approximation algorithms for the densest k-subgraph problem on proper interval graphs and bipartite permutation graphs, Information Processing Letters, vol.110, issue.16, pp.635-638, 2010. ,
DOI : 10.1016/j.ipl.2010.05.011
Detecting high log-densities, Proceedings of the 42nd ACM symposium on Theory of computing, STOC '10, pp.201-210, 2010. ,
DOI : 10.1145/1806689.1806719
A deterministic approximation algorithm for the densest k-subgraph problem, International Journal of Operational Research, vol.3, pp.301-314, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00596169
Set Partitioning via Inclusion-Exclusion, SIAM Journal on Computing, vol.39, issue.2, pp.546-563, 2009. ,
DOI : 10.1137/070683933
Fast algorithms for min independent dominating set, Discrete Applied Mathematics, vol.161, issue.4-5, pp.4-5558, 2013. ,
DOI : 10.1016/j.dam.2012.01.003
URL : https://hal.archives-ouvertes.fr/hal-01508849
Approximation of max independent set, min vertex cover and related problems by moderately exponential algorithms, Discrete Applied Mathematics, vol.159, issue.17, pp.1954-1970, 2011. ,
DOI : 10.1016/j.dam.2011.07.009
URL : http://doi.org/10.1016/j.dam.2011.07.009
Fast Algorithms for max independent set, Algorithmica, vol.7, issue.3, pp.382-415, 2012. ,
DOI : 10.1007/s00453-010-9460-7
URL : https://hal.archives-ouvertes.fr/hal-00880187
The max quasi-independent set problem, Journal of Combinatorial Optimization, vol.20, issue.2, pp.94-117, 2012. ,
DOI : 10.1007/s10878-010-9343-5
URL : https://hal.archives-ouvertes.fr/hal-00880207
Exact and Approximation Algorithms for Densest k-Subgraph, WALCOM'13, pp.114-125, 2013. ,
DOI : 10.1007/978-3-642-36065-7_12
URL : https://hal.archives-ouvertes.fr/hal-01215976
Combining Two Worlds: Parameterised Approximation for Vertex Cover, ISAAC'10, pp.390-402, 2010. ,
DOI : 10.1007/978-3-642-17517-6_35
On colouring the nodes of a network, Mathematical Proceedings of the Cambridge Philosophical Society, vol.37, issue.02, pp.194-197, 1941. ,
DOI : 10.1017/S030500410002168X
Parameterized Complexity of Cardinality Constrained Optimization Problems, The Computer Journal, vol.51, issue.1, pp.102-121, 2007. ,
DOI : 10.1093/comjnl/bxm086
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.100.7121
Fixed-parameter approximation: conceptual framework and approximability results, IWPEC'06, pp.96-108, 2006. ,
DOI : 10.1007/11847250_9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.219.2987
Exact algorithms for problems related to the densest k-set problem, Information Processing Letters, vol.114, issue.9, pp.510-513, 2014. ,
DOI : 10.1016/j.ipl.2014.04.009
Improved upper bounds for vertex cover, Theoretical Computer Science, vol.411, issue.40-42, pp.3736-3756, 2010. ,
DOI : 10.1016/j.tcs.2010.06.026
URL : http://doi.org/10.1016/j.tcs.2010.06.026
Clustering and domination in perfect graphs, Discrete Applied Mathematics, vol.9, issue.1, pp.27-39, 1984. ,
DOI : 10.1016/0166-218X(84)90088-X
URL : http://doi.org/10.1016/0166-218x(84)90088-x
Exponential-time approximation of weighted set cover, Information Processing Letters, vol.109, issue.16, pp.957-961, 2009. ,
DOI : 10.1016/j.ipl.2009.05.003
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.534.2721
Exact and approximate bandwidth, Theoretical Computer Science, vol.411, pp.40-423701, 2010. ,
DOI : 10.1016/j.tcs.2010.06.018
URL : http://doi.org/10.1016/j.tcs.2010.06.018
Parameterized complexity. Monographs in Computer Science, 1999. ,
Parameterized Approximation Problems, IWPEC'06, pp.121-129, 2006. ,
DOI : 10.1007/11847250_11
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.467.9346
The Dense k -Subgraph Problem, Algorithmica, vol.29, issue.3, pp.410-421, 2001. ,
DOI : 10.1007/s004530010050
Approximation Algorithms for Maximization Problems Arising in Graph Partitioning, Journal of Algorithms, vol.41, issue.2, pp.174-211, 2001. ,
DOI : 10.1006/jagm.2001.1183
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.22.1611
On the densest k-subgraph problem, 1997. ,
A measure & conquer approach for the analysis of exact algorithms, Journal of the ACM, vol.56, issue.5, 2009. ,
DOI : 10.1145/1552285.1552286
Pathwidth of cubic graphs and exact algorithms, Information Processing Letters, vol.97, issue.5, pp.191-196, 2006. ,
DOI : 10.1016/j.ipl.2005.10.012
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.66.3486
Quadratic knapsack problems, Mathematical Programming, vol.12, pp.132-149, 1980. ,
DOI : 10.1007/BFb0120892
Finding a maximum density subgraph, 1984. ,
Improved Approximation Algorithms for Maximum Graph Partitioning Problems, Journal of Combinatorial Optimization, vol.90, issue.1, pp.133-167, 2005. ,
DOI : 10.1007/s10878-005-2269-7
Reducibility among combinatorial problems, Complexity of computer computations, pp.85-103, 1972. ,
DOI : 10.1007/978-3-540-68279-0_8
Ruling Out PTAS for Graph Min-Bisection, Densest Subgraph and Bipartite Clique, 45th Annual IEEE Symposium on Foundations of Computer Science, pp.136-145, 2004. ,
DOI : 10.1109/FOCS.2004.59
On Finding Dense Subgraphs, ICALP'09, pp.597-608, 2009. ,
DOI : 10.1007/978-3-642-02927-1_50
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.157.704
An algorithmic framework for fixed-cardinality optimization in sparse graphs applied to dense subgraph problems, Discrete Applied Mathematics, vol.193, pp.145-161, 2015. ,
DOI : 10.1016/j.dam.2015.04.029
A constant approximation algorithm for the densest k-subgraph problem on chordal graphs, Information Processing Letters, vol.108, issue.1, pp.29-32, 2008. ,
DOI : 10.1016/j.ipl.2008.03.016
Parameterized Complexity and Approximation Algorithms, The Computer Journal, vol.51, issue.1, pp.60-78, 2008. ,
DOI : 10.1093/comjnl/bxm048
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.102.728
Exact algorithms for generalizations of vertex cover, 2005. ,
PTAS for Densest $$k$$ k -Subgraph in Interval Graphs, Algorithmica, vol.45, issue.5, pp.528-539, 2016. ,
DOI : 10.1007/s00453-014-9956-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.370.910
Approximation of the Quadratic Knapsack Problem, INFORMS Journal on Computing, vol.28, issue.2, pp.308-318, 2016. ,
DOI : 10.1287/ijoc.2015.0678
The quadratic 0???1 knapsack problem with series???parallel support, Operations Research Letters, vol.30, issue.3, pp.159-166, 2002. ,
DOI : 10.1016/S0167-6377(02)00122-0
Paths, Stars and the Number Three, Combinatorics, Probability and Computing, vol.17, issue.03, pp.277-295, 1996. ,
DOI : 10.1002/net.3230070305
Approximation of the Quadratic Knapsack Problem, Operations Research Letters, vol.44, issue.4, pp.495-497, 2016. ,
DOI : 10.1016/j.orl.2016.05.005
Inclusion/Exclusion Meets Measure and Conquer, ESA'09, pp.554-565, 2009. ,
DOI : 10.1007/978-3-642-04128-0_50
