Relational Presheaves as Labelled Transition Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show that viewing labelled transition systems as relational presheaves captures several recently studied examples. This approach takes into account possible algebraic structure on labels. Weak closure of a labelled transition system is characterised as a left (2-)adjoint to a change-of-base functor.
978-3-642-32784-1_3_Chapter.pdf (311.31 Ko) Télécharger le fichier
hal-01539889 , version 1 (15-06-2017)
Paternité
Paweł Sobociński. Relational Presheaves as Labelled Transition Systems. 11th International Workshop on Coalgebraic Methods in Computer Science (CMCS), Mar 2012, Tallinn, Estonia. pp.40-50, ⟨10.1007/978-3-642-32784-1_3⟩. ⟨hal-01539889⟩
104 Consultations
210 Téléchargements
