FeaStNet: Feature-Steered Graph Convolutions for 3D Shape Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Convolutional neural networks (CNNs) have massively impacted visual recognition in 2D images, and are now ubiquitous in state-of-the-art approaches. CNNs do not easily extend, however, to data that are not represented by regular grids, such as 3D shape meshes or other graph-structured data, to which traditional local convolution operators do not directly apply. To address this problem, we propose a novel graph-convolution operator to establish correspondences between filter weights and graph neighborhoods with arbitrary connectivity. The key novelty of our approach is that these correspondences are dynamically computed from features learned by the network, rather than relying on predefined static coordinates over the graph as in previous work. We obtain excellent experimental results that significantly improve over previous state-of-the-art shape correspondence results. This shows that our approach can learn effective shape representations from raw input coordinates, without relying on shape descriptors.
main.pdf (10.05 Mo) Télécharger le fichier
Format : Figure, Image
hal-01540389 , version 1 (16-06-2017)
hal-01540389 , version 2 (28-03-2018)
Nitika Verma, Edmond Boyer, Jakob Verbeek. FeaStNet: Feature-Steered Graph Convolutions for 3D Shape Analysis. CVPR - IEEE Conference on Computer Vision & Pattern Recognition, 2018, Salt Lake City, United States. ⟨hal-01540389v1⟩
2452 Consultations
1436 Téléchargements
