A posteriori error estimates and stopping criteria for space-time domain decomposition for two-phase flow between different rock types
Abstract : We consider two-phase flow in a porous medium composed of two different rock types, so that the capillary pressure field is discontinuous at the interface between the rocks. This is a nonlinear and degenerate parabolic problem with nonlinear and discontinuous transmission conditions on the interface. We first describe a space-time domain decomposition method based on the optimized Schwarz waveform relaxation algorithm (OSWR) with Robin or Ventcell transmission conditions. Full numerical approximation is achieved by a finite volume scheme in space and the backward Euler scheme in time. We then derive a guaranteed and fully computable a posteriori error estimate which in particular takes into account the domain decomposition error. Precisely, at each iteration of the OSWR algorithm and on each linearization step, the estimate delivers a guaranteed upper bound on the error between the exact and the approximate solution. Furthermore, to make the OSWR algorithm efficient, the different error components given by the spatial discretization, the temporal discretization, the linearization, and the domain decomposition are distinguished. These ingredients are then used to design a stopping criterion for the OSWR algorithm as well as for the linearization iterations, which together lead to important computational savings. Numerical experiments illustrate the efficiency of our estimates and the performance of the OSWR algorithm with adaptive stopping criteria on a model problem in three space dimensions. Additionally, the results show how a posteriori error estimates can help determine the free Robin or Ventcell parameters.
Document type :
Preprints, Working Papers, ...
Complete list of metadatas
Cited literature [46 references]  Display  Hide  Download
https://hal.inria.fr/hal-01540956
Contributor : Caroline Japhet <>
Submitted on : Friday, May 10, 2019 - 7:51:13 PM
Last modification on : Tuesday, February 11, 2020 - 2:07:16 PM
File
Apost2PF.pdf
Identifiers
  • HAL Id : hal-01540956, version 2
Collections
Citation
Elyes Ahmed, Sarah Ali Hassan, Caroline Japhet, Michel Kern, Martin Vohralík. A posteriori error estimates and stopping criteria for space-time domain decomposition for two-phase flow between different rock types. 2017. ⟨hal-01540956v2⟩
Share
Metrics
Record views
75
Files downloads
324
