Abstract : Stream processing engines have been proposed in the past for handling streaming data coming from data sources. But considering sensor networks, there is a need for an approach that allows stream models to reach also computation-capable constrained embedded devices and to implement storage, exchange and computation on those. We propose a stream model that implements sensor-device data handling. The stream processing abstraction and interface allows small motes to store and process the data locally and to route processed data to consumer streams on-demand. This eliminates the need to code motes operation in lower-level languages, allows easy configuration of operations of different types and saves communication energy. The approach is quite useful in diverse contexts, including wireless sensor networks. We describe the approach and show its advantages experimentally.
Gerald Quirchmayr; Josef Basl; Ilsun You; Lida Xu; Edgar Weippl. International Cross-Domain Conference and Workshop on Availability, Reliability, and Security (CD-ARES), Aug 2012, Prague, Czech Republic. Springer, Lecture Notes in Computer Science, LNCS-7465, pp.218-232, 2012, Multidisciplinary Research and Practice for Information Systems. 〈10.1007/978-3-642-32498-7_17〉
https://hal.inria.fr/hal-01542439
Contributeur : Hal Ifip
Soumis le : lundi 19 juin 2017 - 17:01:18
Dernière modification le : mardi 20 juin 2017 - 01:06:35
Document(s) archivé(s) le : vendredi 15 décembre 2017 - 20:10:45
Pedro Furtado. TinyStream Sensors. Gerald Quirchmayr; Josef Basl; Ilsun You; Lida Xu; Edgar Weippl. International Cross-Domain Conference and Workshop on Availability, Reliability, and Security (CD-ARES), Aug 2012, Prague, Czech Republic. Springer, Lecture Notes in Computer Science, LNCS-7465, pp.218-232, 2012, Multidisciplinary Research and Practice for Information Systems. 〈10.1007/978-3-642-32498-7_17〉. 〈hal-01542439〉
