M. T. Ozsu and P. Valduriez, Principles of Distributed Database Systems, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00483354
J. Madhavan, S. Cohen, X. L. Dong, A. Y. Halevy, S. R. Jeffery et al., Web-scale data integration: You can afford to pay as you go, Proc. of CIDR, 2007.
A. D. Sarma, X. Dong, and A. Y. Halevy, Bootstrapping pay-as-you-go data integration systems, Proc. of SIGMOD, 2008.
D. Z. Wang, X. L. Dong, A. D. Sarma, M. J. Franklin, and A. Y. Halevy, Functional dependency generation and applications in pay-as-you-go data integration systems, Proc. of WebDB, 2009.
R. Akbarinia, P. Valduriez, and G. Verger, Efficient Evaluation of SUM Queries over Probabilistic Data, IEEE Transactions on Knowledge and Data Engineering, vol.25, issue.4, 2012.
DOI : 10.1109/TKDE.2012.62
URL : https://hal.archives-ouvertes.fr/lirmm-00652293
X. L. Dong, A. Y. Halevy, and C. Yu, Data integration with uncertainty, The VLDB Journal, vol.29, issue.1, pp.469-500, 2009.
DOI : 10.1007/s00778-008-0119-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.152.6726
Y. Huhtala, J. Kärkkäinen, P. Porkka, and H. Toivonen, Tane: An Efficient Algorithm for Discovering Functional and Approximate Dependencies, The Computer Journal, vol.42, issue.2, pp.100-111, 1999.
DOI : 10.1093/comjnl/42.2.100
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.24.3544
N. Ayat, H. Afsarmanesh, R. Akbarinia, and P. Valduriez, Uncertain data integration using functional dependencies
DOI : 10.1007/978-3-642-32498-7_28
I. Davidson and S. S. Ravi, Using instance-level constraints in agglomerative hierarchical clustering: theoretical and empirical results, Data Mining and Knowledge Discovery, vol.10, issue.2, pp.257-282, 2009.
DOI : 10.1017/CBO9780511813603
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.299.7703
M. Hall, E. Frank, G. Holmes, B. Pfahringer, P. Reutemann et al., The WEKA data mining software, ACM SIGKDD Explorations Newsletter, vol.11, issue.1, pp.10-18, 2009.
DOI : 10.1145/1656274.1656278
W. W. Cohen, P. D. Ravikumar, and S. E. Fienberg, A comparison of string distance metrics for name-matching tasks, Proc. of IIWeb, 2003.
E. Rahm and P. A. Bernstein, A survey of approaches to automatic schema matching, The VLDB Journal, vol.10, issue.4, pp.334-350, 2001.
DOI : 10.1007/s007780100057
J. Biskup and D. W. Embley, Extracting information from heterogeneous information sources using ontologically specified target views, Information Systems, vol.28, issue.3, pp.169-212, 2003.
DOI : 10.1016/S0306-4379(02)00009-1
URL : http://blondie.cs.byu.edu/CS652/biscup02extracting.pdf
J. A. Larson, S. B. Navathe, and R. Elmasri, A theory of attributed equivalence in databases with application to schema integration, IEEE Transactions on Software Engineering, vol.15, issue.4, pp.449-463, 1989.
DOI : 10.1109/32.16605
