XQuery 1.0: An XML Query Language, W3C working draft, 2001. ,
XML Path Language (XPath) version 1.0,W3C recommendation, 1999. ,
Maintaining order in a linked list, Proceedings of the fourteenth annual ACM symposium on Theory of computing , STOC '82, 1982. ,
DOI : 10.1145/800070.802184
Indexing and Querying XML Data for Regular Path Expressions, Proceedings of the VLDB, 2001. ,
Dynamic interval-based labeling scheme for efficient XML query and update processing, Journal of Systems and Software, vol.81, issue.1, 2008. ,
DOI : 10.1016/j.jss.2007.05.034
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.483.386
Labeling Dynamic XML Trees, Proceedings of the ACM SIGMOD-SIGACT-SiGART, 2002. ,
DOI : 10.1145/543645.543648
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.126.4577
Storing and querying ordered XML using a relational database system, Proceedings of the 2002 ACM SIGMOD international conference on Management of data , SIGMOD '02, 2002. ,
DOI : 10.1145/564691.564715
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.5927
ORDPATHs, Proceedings of the 2004 ACM SIGMOD international conference on Management of data , SIGMOD '04, 2004. ,
DOI : 10.1145/1007568.1007686
LSDX: New Labeling Scheme for Dynamically Updating XML Data, Proceedings of 16th Australian Database Conference, 2005. ,
Dynamic Labeling Scheme for XML Data Processing, On the Move to Meaningful Internet Systems: OTM, 2008. ,
DOI : 10.1007/978-3-540-88873-4_19
XMark, Proceedings of VLDB, 2002. ,
DOI : 10.1016/B978-155860869-6/50096-2
Transaction Processing: Concepts and Techniques, 1993. ,
ARIES/IM: an efficient and high concurrency index management method using write-ahead logging, ACM SIGMOD Record, vol.21, issue.2, pp.371-380, 1992. ,
DOI : 10.1145/141484.130338
Applying Dewey Encoding to Construct XML Index for Path and Keyword Query, 2009 First International Workshop on Database Technology and Applications, 2009. ,
DOI : 10.1109/DBTA.2009.129
A Structural Numbering Scheme for XML Data, Lecure Notes in Computer Science 2490, 2002. ,
DOI : 10.1007/3-540-36128-6_6
A Dynamic Labeling Scheme Using Vectors, Proceedings of the 18th International Conference on Database and Expert Systems Applications (DEXA), 2007. ,
DOI : 10.1007/978-3-540-74469-6_14
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.62.4869
Labeling dynamic XML Documents: An Order-centric Approach, IEEE Transactions on Knowledge and Data Engineering, 2012. ,
A prime number labeling scheme for dynamic ordered XML trees, Proceedings. 20th International Conference on Data Engineering, 2004. ,
DOI : 10.1109/ICDE.2004.1319985
A Persistent Labeling Scheme for XML and tree Database, Proceedings of ACI, 2006. ,
Dynamic Labeling Schemes for Ordered XML Based on Type Information, Seventeenth Australasian Database Conference Technology, 2006. ,
BOXes: Efficient Maintenance of Order-Based Labeling for Dynamic XML Data, 21st International Conference on Data Engineering (ICDE'05), 2005. ,
DOI : 10.1109/ICDE.2005.29
A Concise Labeling Scheme for XML Data, International Conference on Management of Data COMAD, 2006. ,
DDE, Proceedings of the 35th SIGMOD international conference on Management of data, SIGMOD '09, 2009. ,
DOI : 10.1145/1559845.1559921
Dynamic interval-based labeling scheme for efficient XML query and update processing, Journal of Systems and Software, vol.81, issue.1, pp.56-70, 2008. ,
Extending path summary and region encoding for efficient structural query processing in native XML databases, Journal of Systems and Software, vol.82, issue.6, 2009. ,
DOI : 10.1016/j.jss.2009.01.007
Sedna: A Native XML DBMS, the 32nd Conference on Current Trends in Theory and Practice of Computer Science, 2006. ,
DOI : 10.1007/11611257_25
XQuery Implementation in a Relational Database system, Proceedings of the 31 st International Conference on VLDB, 2005. ,
Some Rewrite Optimizations of DB2 XQuery Navigation, p.8, 2008. ,
Efficient Processing of XML Twig Pattern: A Novel One-Phase Holistic Solution, 2007. ,
DOI : 10.1007/978-3-540-74469-6_10
Fast Matching of Twig Patterns, Proceedings of the 19th International Conference on Database and Expert Systems Applications, 2008. ,
DOI : 10.1007/978-3-540-85654-2_45
