Principles of artificial neural networks. p. 303. In: Circuits and systems, 2007. ,
Performance and exhaust emissions of a gasoline engine with ethanol blended gasoline fuels using artificial neural network, Applied Energy, vol.86, issue.5, pp.630-639, 2009. ,
DOI : 10.1016/j.apenergy.2008.09.017
An analysis for effect of cetane number on exhaust emissions from engine with the neural network, Fuel, vol.81, issue.15, pp.1963-70, 2003. ,
DOI : 10.1016/S0016-2361(02)00112-6
Prediction of performance and exhaust emissions of a diesel engine fueled with biodiesel produced from waste frying palm oil, Expert Systems with Applications, vol.36, issue.5, pp.9268-9280, 2009. ,
DOI : 10.1016/j.eswa.2008.12.005
Artificial neural-network based modeling of variable valve-timing in a spark-ignition engine, Applied Energy, vol.81, issue.2, pp.187-97, 2005. ,
DOI : 10.1016/j.apenergy.2004.07.008
Artificial intelligence for the modeling and control of combustion processes: a review, Progress in Energy and Combustion Science, vol.29, issue.6, pp.515-66, 2003. ,
DOI : 10.1016/S0360-1285(03)00058-3
A neural network model-based observer for idle speed control of ignition in SI engine, Engineering Applications of Artificial Intelligence, vol.23, issue.1, pp.1-7, 2010. ,
DOI : 10.1016/j.engappai.2009.09.008
Application of artificial neural-networks for energy systems, Applied Energy, vol.7, pp.17-35, 2006. ,
Power plant condenser performance forecasting using a non-fully connected artificial neural network, Energy, vol.26, issue.1, pp.65-79, 2001. ,
DOI : 10.1016/S0360-5442(00)00046-3
Modeling of thermodynamic properties using neural networks, Fluid Phase Equilibria, vol.199, issue.1-2, pp.53-62, 2002. ,
DOI : 10.1016/S0378-3812(01)00801-9
A new approach to thermodynamic analysis of ejector???absorption cycle: artificial neural networks, Applied Thermal Engineering, vol.23, issue.8, pp.937-52, 2003. ,
DOI : 10.1016/S1359-4311(03)00034-6
Performance comparison of CFCs with their substitutes using artificial neural network, International Journal of Energy Research, vol.28, issue.12, pp.1113-1138, 2004. ,
DOI : 10.1002/er.1020
Artificial neural network analysis of a refrigeration system with an evaporative condenser, Applied Thermal Engineering, vol.26, issue.5-6, pp.627-662, 2006. ,
DOI : 10.1016/j.applthermaleng.2005.06.002
Development of an artificial neural network model for the steam process of a coal biomass cofired combined heat and power (CHP) plant in Sweden, Energy, vol.32, pp.2099-109, 2007. ,
Mathematical modeling of cooking pots? thermal efficiency using a combined experimental and neural network method, Energy, vol.31, issue.14, pp.31-2969, 2007. ,
DOI : 10.1016/j.energy.2005.11.006
Performance and exhaust emissions of a biodiesel engine, Applied Energy, vol.83, issue.6, pp.594-605, 2006. ,
DOI : 10.1016/j.apenergy.2005.05.003
A diesel engine's performance and exhaust emissions, Applied Energy, vol.80, issue.1, pp.11-22, 2005. ,
DOI : 10.1016/j.apenergy.2004.03.004
Performance maps of a diesel engine, Applied Energy, vol.81, issue.3, pp.247-59, 2005. ,
DOI : 10.1016/j.apenergy.2004.08.003
Application of artificial neural network to predict specific fuel consumption and exhaust temperature for a Diesel engine, Applied Thermal Engineering, vol.26, issue.8-9, pp.824-832, 2006. ,
DOI : 10.1016/j.applthermaleng.2005.10.006
Diesel engine performance and exhaust emission analysis using waste cooking biodiesel fuel with an artificial neural network, Renewable Energy, vol.34, issue.4, pp.976-82, 2009. ,
DOI : 10.1016/j.renene.2008.08.008
URL : http://eprints.usq.edu.au/5001/3/Ghobadian_Rahimi_Nikbakht_Najafi_Yusaf__2009_Author_postprint.pdf.pdf
Performance and exhaust emissions of a gasoline engine using artificial neural network, Applied Thermal Engineering, vol.27, issue.1, pp.46-54, 2007. ,
DOI : 10.1016/j.applthermaleng.2006.05.016
Application of artificial neural networks for the prediction of performance and exhaust emissions in SI engine using ethanol- gasoline blends, Energy, vol.35, issue.1, pp.65-69, 2010. ,
DOI : 10.1016/j.energy.2009.08.034
Thermal balance of a LPG fuelled, four stroke SI engine with water addition. Energy Conversion and Management, pp.570-581, 2006. ,
