Autonomous Sensor Network Architecture Model - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
To implement a maintenance free and reliable sensor network is necessary in complex sensor systems nowadays. There are studies, which can control developers, who want to build an autonomous sensor network in a dynamically changing environment. The existing solutions have several drawbacks because of the diversity and complexity of the wireless type sensor networks. This paper introduces a sensor network architecture model, which is a good base to implement a simulation environment for the systems before implementing them. The introduced features make the possibility to fine-tune the operational parameters during the planning phase. In this way, the presented sensor network architecture is working based on the presented roles to provide its services.
978-3-642-32808-4_27_Chapter.pdf (319.12 Ko) Télécharger le fichier
Dates and versions
hal-01543177 , version 1 (20-06-2017)
Attribution - CC BY 4.0
Identifiers
Cite
András Tóth, Ferenc Vajda. Autonomous Sensor Network Architecture Model. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.298-308, ⟨10.1007/978-3-642-32808-4_27⟩. ⟨hal-01543177⟩
69 View
51 Download
Share
