Abstract : In this article a maturity model is proposed, named OD-MM (Open Data Maturity Model) to assess the commitment and capabilities of public agencies in pursuing the principles and practices of open data. The OD-MM model has a three level hierarchical structure, called domains, sub-domains and critical variables. Four capacity levels are defined for each of the 33 critical variables distributed in nine sub-domains in order to determine the organization maturity level. The model is a very valuable diagnosis tool for public services, given it shows all weaknesses and the way (a roadmap) to progress in the implementation of open data.
https://hal.inria.fr/hal-01543587
Contributor : Hal Ifip <>
Submitted on : Wednesday, June 21, 2017 - 10:07:57 AM Last modification on : Wednesday, June 21, 2017 - 10:09:02 AM Long-term archiving on: : Friday, December 15, 2017 - 8:27:47 PM
Mauricio Solar, Gastón Concha, Luis Meijueiro. A Model to Assess Open Government Data in Public Agencies. 11th International Conference on Electronic Government (EGOV), Sep 2012, Kristiansand, Norway. pp.210-221, ⟨10.1007/978-3-642-33489-4_18⟩. ⟨hal-01543587⟩
