Compressive Statistical Learning with Random Feature Moments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Statistics and Learning Année : 2021
We describe a general framework --compressive statistical learning-- for resource-efficient large-scale learning: the training collection is compressed in one pass into a low-dimensional sketch (a vector of random empirical generalized moments) that captures the information relevant to the considered learning task. A near-minimizer of the risk is computed from the sketch through the solution of a nonlinear least squares problem. We investigate sufficient sketch sizes to control the generalization error of this procedure. The framework is illustrated on compressive PCA, compressive clustering, and compressive Gaussian mixture Modeling with fixed known variance. The latter two are further developed in a companion paper.
Compressive_learning_sanitized_source.pdf (638.41 Ko) Télécharger le fichier
hal-01544609 , version 1 (21-06-2017)
hal-01544609 , version 2 (06-12-2017)
hal-01544609 , version 3 (16-04-2020)
hal-01544609 , version 4 (23-03-2021)
hal-01544609 , version 5 (21-06-2021)
Rémi Gribonval, Gilles Blanchard, Nicolas Keriven, Yann Traonmilin. Compressive Statistical Learning with Random Feature Moments. Mathematical Statistics and Learning, In press. ⟨hal-01544609v4⟩
1274 Consultations
1157 Téléchargements
