Less effective selection leads to larger genomes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Genome Research Année : 2017
Andaine Seguin-Orlando
Luca Ermini
Clio Der Sarkissian
The evolutionary origin of the striking genome size variations found in eukaryotes remains enigmatic. The effective size of populations, by controlling selection efficacy, is expected to be a key parameter underlying genome size evolution. However, this hypothesis has proved difficult to investigate using empirical datasets. Here, we tested this hypothesis using twenty-two de novo transcriptomes and low-coverage genomes of asellid isopods, which represent eleven independent habitat shifts from surface water to resource-poor groundwater. We show that these habitat shifts are associated with higher transcriptome-wide dN/dS. After ruling out the role of positive selection and pseudogenization, we show that these transcriptome-wide dN/dS increases are the consequence of a reduction in selection efficacy imposed by the smaller effective population size of subterranean species. This reduction is paralleled by an important increase in genome size (25% increase on average), an increase also confirmed in subterranean decapods and mollusks. We also control for an adaptive impact of genome size on life history traits but find no correlation between body size, or growth rate, and genome size. We show instead that the independent increases in genome size measured in subterranean isopods are the direct consequence of increasing invasion rates by repeated elements, which are less efficiently purged out by purifying selection. Contrary to selection efficacy, polymorphism is not correlated to genome size. We propose that recent demographic fluctuations and the difficulty to observe polymorphism variations in polymorphism-poor species can obfuscate the link between effective population size and genome size when polymorphism data is used alone.
GenomeSize_57.pdf (444.67 Ko) Télécharger le fichier
hal-01544879 , version 2 (30-05-2017)
hal-01544879 , version 1 (22-06-2017)
Tristan Lefébure, Claire Morvan, Florian Malard, Clémentine François, Lara Konecny-Dupré, et al.. Less effective selection leads to larger genomes. Genome Research, 2017, 27, pp.1016-1028. ⟨10.1101/gr.212589.116⟩. ⟨hal-01544879v2⟩
748 Consultations
431 Téléchargements
