Computing the Homology of Basic Semialgebraic Sets in Weak Exponential Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the ACM (JACM) Année : 2018
We describe and analyze an algorithm for computing the homology (Betti numbers and torsion coefficients) of basic semialgebraic sets which works in weak exponential time. That is, out of a set of exponentially small measure in the space of data the cost of the algorithm is exponential in the size of the data. All algorithms previously proposed for this problem have a complexity which is doubly exponential (and this is so for almost all data).
Semialgebraic.pdf (892.9 Ko) Télécharger le fichier
hal-01545657 , version 1 (22-06-2017)
hal-01545657 , version 2 (19-12-2018)
Peter Bürgisser, Felipe Cucker, Pierre Lairez. Computing the Homology of Basic Semialgebraic Sets in Weak Exponential Time. Journal of the ACM (JACM), 2018, 66 (1), pp.1-30. ⟨10.1145/3275242⟩. ⟨hal-01545657v2⟩
292 Consultations
209 Téléchargements
