Model-Based Feedforward Optimal Control applied to a Turbulent Separated Flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper presents a model-based optimal feedforward control methodology applied to the control of a separated flow. A model is first identified as a delayed bilinear model from experimental data using a special identification procedure, for which the precision is compared to other existing results. Then, using the identified model, the optimal feedforward control problem is formulated and solved for the case of a periodic relay control. The theoretical control results are supported with numerical simulations.
Automatique
main_MF_v1.pdf (4.22 Mo) Télécharger le fichier
hal-01546424 , version 1 (23-06-2017)
  • HAL Id : hal-01546424 , version 1
Maxime Feingesicht, Andrey Polyakov, Franck Kerhervé, Jean-Pierre Richard. Model-Based Feedforward Optimal Control applied to a Turbulent Separated Flow. IFAC 2017 - 20th World Congress of the International Federation of Automatic Control, Jul 2017, Toulouse, France. pp.6. ⟨hal-01546424⟩
252 Consultations
141 Téléchargements
