Model Reduction and Control of a Cavity-Driven Separated Boundary Layer, IU- TAM Symposium on Flow Control and MEMS, pp.147-155, 2008. ,
DOI : 10.1007/978-1-4020-6858-4_17
URL : https://hal.archives-ouvertes.fr/hal-00420783
Mesh Adaptive Direct Search Algorithms for Constrained Optimization, SIAM Journal on Optimization, vol.17, issue.1, pp.188-217, 2006. ,
DOI : 10.1137/040603371
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.413.9526
Nonsmooth optimization through Mesh Adaptive Direct Search and Variable Neighborhood Search, Journal of Global Optimization, vol.39, issue.2, pp.299-318, 2007. ,
DOI : 10.1007/s10898-007-9234-1
Globalization strategies for?Mesh Adaptive Direct Search, Computational Optimization and Applications, vol.7, issue.1, pp.193-215, 2009. ,
DOI : 10.1137/1.9780898718768
Closed-Loop Turbulence Control: Progress and Challenges, Applied Mechanics Reviews, vol.67, issue.5, 2015. ,
DOI : 10.1115/1.4031175
Experimental closed-loop control of flow separation over a plain flap using slope seeking, Experiments in Fluids, vol.49, issue.7, pp.55-56, 2014. ,
DOI : 10.2514/1.J050702
Experimental detection of flow separation over a plain flap by wall shear stress analysis with and without steady blowing, Comptes Rendus M?canique, vol.342, issue.6-7, pp.342-389, 2014. ,
DOI : 10.1016/j.crme.2014.01.013
Control of turbulent separated flow over a backward-facing step by local forcing, Experiments in Fluids, vol.101, issue.6, pp.417-426, 1996. ,
DOI : 10.1017/S0022112080001760
Electromagnetic Control of Separated Flows Using Periodic Excitation with Different Wave Forms, Active Flow Control, number 95 in Notes on Numerical Fluid Mechanics and Multidisciplinary Design (NNFM), pp.27-41, 2007. ,
DOI : 10.1007/978-3-540-71439-2_2
An Overview of Recent DLR Contributions on Active Flow-Separation Control Studies for High-Lift Configurations, Aerospace Lab, pp.2013-2019, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01184651
NARX modelling of unsteady separation control, Experiments in Fluids, vol.46, issue.1, pp.1-17, 2013. ,
DOI : 10.1007/978-1-4613-0465-4
Machine Learning Control ? Taming Nonlinear Dynamics and Turbulence, 2016. ,
DOI : 10.1007/978-3-319-40624-4
Active Control of a Separating Boundary Layer with Steady Vortex Generating Jets - Detailed Flow Measurements, 42nd AIAA Aerospace Sciences Meeting and Exhibit, 2004. ,
DOI : 10.1115/1.1350410
A bilinear input-output model with state-dependent delay for separated flow control. URL https, 2016. ,
DOI : 10.1109/ecc.2016.7810532
URL : https://hal.archives-ouvertes.fr/hal-01298166
Local exact controllability of the Navier???Stokes system, Journal de Math??matiques Pures et Appliqu??es, vol.83, issue.12, pp.1501-1542, 2004. ,
DOI : 10.1016/j.matpur.2004.02.010
Introduction to Time-Delay Systems: Analysis and Control, 2014. ,
DOI : 10.1007/978-3-319-09393-2
A separation principle for bilinear systems with dissipative drift, IEEE Transactions on Automatic Control, vol.37, issue.12, pp.1970-1974, 1992. ,
DOI : 10.1109/9.182484
Optimal Control of Two- and Three-Dimensional Incompressible Navier?Stokes Flows, Journal of Computational Physics, vol.136, issue.2, pp.231-244, 1997. ,
DOI : 10.1006/jcph.1997.5744
Caratheodory Conditions, Functional Differential Equations, number 3 in Applied Mathematical Sciences, pp.30-31, 1971. ,
DOI : 10.1007/978-1-4615-9968-5_7
Functional Analysis, 1982. ,
Algorithm 909, ACM Transactions on Mathematical Software, vol.37, issue.4, p.44, 2011. ,
DOI : 10.1145/1916461.1916468
Pulsed vortex generator jets for active control of flow separation, Fluid Dynamics Conference, 1994. ,
DOI : 10.1007/BF00223244
Generalized fixed-point theorems and periodic solutions of non-linear equations, 2006. ,
Experimental open-loop and closed-loop control of a massive separated boundary layer at, 2015. ,
Characterization of the transient of a separated turbulent boundary layer under control and applications to advanced closed-loop controllers, 2015. ,
Characterisation of the Transient Dynamics of a Controlled Separated Flow Using Phase Averaged PIV, International Conference on Instability and Control of Massively Separated Flows ? ICOMASEF, 2013. ,
DOI : 10.1007/978-3-319-06260-0_27
Experimental closed-loop control of a detached boundary layer at high Reynolds number, 10th EUROMECH Fluid Mechanics Conference, 2014. ,
Control of low-speed turbulent separated flow using jet vortex generators, Experiments in Fluids, vol.11, issue.6, pp.394-400, 1992. ,
DOI : 10.1115/1.3243608
Open and closed-loop experiments to identify the separated flow dynamics of a thick turbulent boundary layer, Experiments in Fluids, vol.31, issue.7, pp.1-22, 2013. ,
DOI : 10.2514/6.2006-3016
URL : https://hal.archives-ouvertes.fr/hal-00841368
Separation Control on Low-Pressure Turbine Airfoils Using Synthetic Vortex Generator Jets, pp.2003-38729, 2003. ,
DOI : 10.1115/gt2003-38729
Optimal control of the unsteady Navier-Stokes equations, 2006. ,
