Characterization of the nonlinear behaviour and the failure of human liver capsule through inflation tests Experimental mechanical characterization of abdominal organs: liver, kidney & spleen, J. Mech. Behav. Biomed. Mater. J. Mech. Behav. Biomed. Mater, vol.43, issue.17, pp.1572-81, 2002. ,
Contractions, a risk for premature rupture of fetal membranes: a new protocol with cyclic biaxial tension. Characterization of the anisotropic mechanical properties of excised human skin Methodology to study intimal failure mechanics in human internal carotid arteries, Stemper, N. Yoganandan, and F. a Pintar, pp.846-51, 2005. ,
An investigation into the effects of the hierarchical structure of tendon fascicles on micromechanical properties, Proc. Inst, pp.109-128, 2004. ,
DOI : 10.1152/physrev.2001.81.2.685
Investigating load relaxation mechanics in tendon, Journal of the Mechanical Behavior of Biomedical Materials, vol.1, issue.1, pp.51-58, 2008. ,
DOI : 10.1016/j.jmbbm.2007.03.002
Measuring Strain Distributions in Tendon using Confocal Microscopy and Finite Elements Force--Strain Mechanism of Collagen Fibrils and Relations of Tendon At Each Level of Structural Monitoring micrometer-scale collagen organization in rat-tail tendon upon mechanical strain using second harmonic microscopy, J. Strain Anal. Eng. Des. Science J. Biomech, vol.448010, issue.44 11, pp.327-335, 1995. ,
Deformationally dependent fluid transport properties of porcine coronary arteries based on location in the coronary vasculature, Journal of the Mechanical Behavior of Biomedical Materials, vol.17, pp.296-306, 2013. ,
DOI : 10.1016/j.jmbbm.2012.10.002
Adaptation of a Planar Microbiaxial Optomechanical Device for the Tubular Biaxial Microstructural and Macroscopic Characterization of Small Vascular Tissues, Journal of Biomechanical Engineering, vol.16, issue.7, p.75001, 2011. ,
DOI : 10.1111/j.1365-2613.2010.00746.x
Molecular orientation of collagen in intact planar connective tissues under biaxial stretch Collagen orientation and molecular spacing during creep and stress-relaxation in soft connective tissues Effect of fiber distribution and realignment on the nonlinear and inhomogeneous mechanical properties of human supraspinatus tendon under longitudinal tensile loading Tensile properties and fiber alignment of human supraspinatus tendon in the transverse direction demonstrate inhomogeneity, nonlinearity, and regional isotropy, Acta Biomater. J. Exp. Biol. J. Orthop. Res. J. Biomech, vol.1, issue.43 4, pp.45-54, 1998. ,
Role of elastin in spontaneously hypertensive rat small mesenteric artery remodelling, J. Physiol, vol.552, pp.185-195, 2003. ,
Image Correlation Spectroscopy of Multiphoton Images Correlates with Collagen Mechanical Properties Quantification of the Temporal Evolution of Collagen Orientation in Mechanically Conditioned Engineered Cardiovascular Tissues, Fenestrations of the carotid internal elastic lamina and structural adaptation in stroke-prone spontaneously hypertensive rats, pp.1101-1107, 2001. ,
Imaging cells and extracellular matrix in vivo by using second-harmonic generation and two-photon excited fluorescence, Proceedings of the National Academy of Sciences, vol.47, issue.1, pp.11014-11023, 2002. ,
DOI : 10.1146/annurev.physchem.47.1.555
Imaging Coronary Artery Microstructure Using Second-Harmonic and Two-Photon Fluorescence Microscopy, Biophysical Journal, vol.87, issue.4, pp.2778-2786, 2004. ,
DOI : 10.1529/biophysj.104.042887
Studies on the chemical nature of elastin fluorescence, Biochimica et Biophysica Acta (BBA) - Protein Structure, vol.625, issue.2, pp.248-54, 1980. ,
DOI : 10.1016/0005-2795(80)90288-3
Changes induced by ozone and ultraviolet light in type I collagen. Bovine Achilles tendon collagen versus rat tail tendon collagen, European Journal of Biochemistry, vol.60, issue.2, pp.299-306, 1985. ,
DOI : 10.1016/0005-2795(79)90225-3
Isolation and characterization of a fluorescent material in bovine achilles tendon collagen, Biochemical and Biophysical Research Communications, vol.76, issue.4, pp.1124-1129, 1977. ,
DOI : 10.1016/0006-291X(77)90972-X
QUANTITATIVE OPTICAL SPECTROSCOPY FOR TISSUE DIAGNOSIS, Annual Review of Physical Chemistry, vol.47, issue.1, pp.555-606, 1996. ,
Three-Dimensional High-Resolution Second-Harmonic Generation Imaging of Endogenous Structural Proteins in Biological Tissues, Biophysical Journal, vol.82, issue.1, pp.493-508, 2002. ,
DOI : 10.1016/S0006-3495(02)75414-3
Fundamental Limits in Confocal Microscopy Contrast , resolution , pixelation , dynamic range and signal-to-noise ratio : fundamental limits to resolution in fluorescence light microscopy Minimizing photobleaching during confocal microscopy of fluorescent probes bound to chromatin: role of anoxia and photon flux, J. Microsc, vol.189, issue.215, pp.20-42, 1998. ,
Photobleaching, Handbook Of Biological Confocal Microscopy SE -39, J. B. Pawley, pp.690-702, 2006. ,
DOI : 10.1007/978-0-387-45524-2_39
Study on factors enhancing photobleaching effect of fluorescent dye, Measurement, vol.46, issue.4, pp.1393-1398, 2013. ,
DOI : 10.1016/j.measurement.2012.11.039
Photobleaching of Arterial Fluorescent Compounds: Characterization of Elastin, Collagen and Cholesterol Time-resolved Spectra during Prolonged Ultraviolet Irradiation, Photochemistry and Photobiology, vol.45, issue.6, pp.713-734, 1999. ,
DOI : 10.1042/bj1470215
Photobleaching kinetics of fluorescein in quantitative fluorescence microscopy Photobleaching correction in fluorescence microscopy images, Biophys. J. J. Phys. Conf. Ser, vol.6836, issue.90, pp.2588-600, 1995. ,
Chemical mechanism of photobleaching of poly-3BCMU film, Journal of Photochemistry and Photobiology A: Chemistry, vol.95, issue.3, pp.239-244, 1996. ,
DOI : 10.1016/1010-6030(95)04243-1
Mobility measurement by analysis of fluorescence photobleaching recovery kinetics, Biophysical Journal, vol.16, issue.9, pp.1055-69, 1976. ,
DOI : 10.1016/S0006-3495(76)85755-4
Advanced fluorescence microscopy techniques, Molecules, vol.1739, issue.4, pp.4047-132, 2012. ,
Fluorescence localization after photobleaching (FLAP): a new method for studying protein dynamics in living cells, Journal of Microscopy, vol.14, issue.1, pp.109-121, 2002. ,
DOI : 10.1038/nbt1096-1252
The micro-structural strain response of tendon, Journal of Materials Science, vol.24, issue.8, pp.8957-8965, 2007. ,
DOI : 10.1016/S0304-4165(02)00144-7
Photobleaching in Two-Photon Excitation Microscopy, Biophysical Journal, vol.78, issue.4, pp.2159-62, 2000. ,
DOI : 10.1016/S0006-3495(00)76762-2
Experimental investigation of the elastic???plastic deformation of mineralized lobster cuticle by digital image correlation, Journal of Structural Biology, vol.155, issue.3, pp.409-434, 2006. ,
DOI : 10.1016/j.jsb.2006.06.004
Evaluating the Mechanical Behavior of Arterial Tissue using Digital Image Correlation Mechanical characterization of liver capsule through uniaxial quasi-static tensile tests until failure, Dic, pp.409-416, 2002. ,
Physico-chemical and microstructural changes in collagen fiber bundles following stretch in-vitro, Biorheology, vol.25, issue.4, pp.591-603, 1988. ,
DOI : 10.3233/BIR-1988-25401
Effect of cyclic and static tensile loading on water content and solute diffusion in canine flexor tendons: Anin Vitro study, ) (n=4) 2.7 (SD 0.1) (n=4) 2 grids of photobleaching 4.2 (SD 0.4) (n=4) 2.7 (SD 0.1) (n=4) 3 grids of photobleaching 4.8 (SD 1.4) (n=4) 2.8 (SD 0.2), pp.350-356, 1994. ,
DOI : 10.1016/S0363-5023(77)80096-8
