Rate of convergence of the Nesterov accelerated gradient method in the subcritical case ? ? 3, 2017. ,
Fast inertial dynamics and fista algorithms in convex optimization. perturbation aspects. arXiv preprint, 2015. ,
Fast convergence of inertial dynamics and algorithms with asymptotic vanishing viscosity, Mathematical Programming, pp.1-53, 2016. ,
DOI : 10.1137/110844805
THE HEAVY BALL WITH FRICTION METHOD, I. THE CONTINUOUS DYNAMICAL SYSTEM: GLOBAL EXPLORATION OF THE LOCAL MINIMA OF A REAL-VALUED FUNCTION BY ASYMPTOTIC ANALYSIS OF A DISSIPATIVE DYNAMICAL SYSTEM, Communications in Contemporary Mathematics, vol.4, issue.01, pp.1-34, 2000. ,
DOI : 10.1016/0304-4068(76)90019-7
Asymptotic for the perturbed heavy ball system with vanishing damping term. arXiv preprint, 2016. ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
On the long time behavior of second order differential equations with asymptotically small dissipation . Transactions of the, pp.3615983-6017, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00790021
On the Convergence of the Iterates of the ???Fast Iterative Shrinkage/Thresholding Algorithm???, Journal of Optimization Theory and Applications, vol.155, issue.2, pp.968-982, 2015. ,
DOI : 10.1007/978-1-4419-9467-7
Analyse numérique etéquationsetéquations aux dérivées partielles, EDP Sciences, 2006. ,
Asymptotic for a second order evolution equation with convex potential and vanishing damping term. arXiv preprint, 2015. ,
A method of solving a convex programming problem with convergence rate o (1/k2), In Soviet Mathematics Doklady, vol.27, pp.372-376, 1983. ,
A differential equation for modeling nesterov's accelerated gradient method: theory and insights, Journal of Machine Learning Research, vol.17, issue.153, pp.1-43, 2016. ,
