New interface
Conference papers
Computability of Perpetual Exploration in Highly Dynamic Rings
Marjorie Bournat 1 Swan Dubois 1 Franck Petit 1
1 Regal - Large-Scale Distributed Systems and Applications
LIP6 - Laboratoire d'Informatique de Paris 6, Inria de Paris
Abstract : We consider systems made of autonomous mobile robots evolving in highly dynamic discrete environment, i.e., graphs where edges may appear and disappear unpredictably without any recurrence, stability, nor periodicity assumption. Robots are uniform (they execute the same algorithm), they are anonymous (they are devoid of any observable ID), they have no means allowing them to communicate together, they share no common sense of direction, and they have no global knowledge related to the size of the environment. However, each of them is endowed with persistent memory and is able to detect whether it stands alone at its current location. A highly dynamic environment is modeled by a graph such that its topology keeps continuously changing over time. In this paper, we consider only dynamic graphs in which nodes are anonymous, each of them is infinitely often reachable from any other one, and such that its underlying graph (i.e., the static graph made of the same set of nodes and that includes all edges that are present at least once over time) forms a ring of arbitrary size. In this context, we consider the fundamental problem of perpetual exploration: each node is required to be infinitely often visited by a robot. This paper analyses the computability of this problem in (fully) synchronous settings, i.e., we study the deterministic solvability of the problem with respect to the number of robots. We provide three algorithms and two impossibility results that characterize, for any ring size, the necessary and sufficient number of robots to perform perpetual exploration of highly dynamic rings.
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-01548109
Contributor : Swan Dubois Connect in order to contact the contributor
Submitted on : Friday, July 7, 2017 - 9:17:43 AM
Last modification on : Wednesday, June 8, 2022 - 12:50:04 PM
Long-term archiving on: : Wednesday, January 24, 2018 - 8:30:23 AM
File
main.pdf
Identifiers
  • HAL Id : hal-01548109, version 1
Citation
Marjorie Bournat, Swan Dubois, Franck Petit. Computability of Perpetual Exploration in Highly Dynamic Rings. The 37th IEEE International Conference on Distributed Computing Systems (ICDCS 2017) , Jun 2017, Atlanta, United States. ⟨hal-01548109⟩
Share
Metrics
Record views
187
Files downloads
103
