A Type-based Analysis of Causality Loops in Hybrid Systems Modelers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Hybrid Systems Année : 2017
Explicit hybrid systems modelers like Simulink/Stateflow allow for programming both discrete-and continuous-time behaviors with complex interactions between them. An important step in their compilation is the static detection of algebraic or causality loops. Such loops can cause simulations to deadlock and prevent the generation of statically scheduled code. This paper addresses this issue for a hybrid modeling language that combines synchronous data-flow equations with Ordinary Differential Equations (ODEs). We introduce the operator last x for the left-limit of a signal x. The last x operator is used to break causality loops and permits a uniform treatment of discrete and continuous state variables. The semantics of the language relies on non-standard analysis, defining an execution as a sequence of infinitesimally small steps. A signal is deemed causally correct when it can be computed sequentially and only changes infinitesimally outside of announced discrete events like zero-crossings. The causality analysis takes the form of a type system that expresses dependencies between signals. In well-typed programs, signals are provably continuous during integration provided that imported external functions are also continuous, and sequential code can be generated. The effectiveness of the system is illustrated with several examples written in Zélus, a Lustre-like synchronous language extended with ODEs.
paper.pdf (863.63 Ko) Télécharger le fichier
hal-01549183 , version 1 (28-06-2017)
hal-01549183 , version 2 (30-06-2017)
Albert Benveniste, Timothy Bourke, Benoît Caillaud, Bruno Pagano, Marc Pouzet. A Type-based Analysis of Causality Loops in Hybrid Systems Modelers. Nonlinear Analysis: Hybrid Systems, 2017, 26, pp.168-189. ⟨10.1016/j.nahs.2017.04.004⟩. ⟨hal-01549183v2⟩
702 Consultations
582 Téléchargements
