Polynomial Interpolation of the Naor-Reingold Pseudo-Random Function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applicable Algebra in Engineering, Communication and Computing Année : 2017
We prove lower bounds on the degree of polynomials interpolating the Naor–Reingold pseudo-random function over a finite field and over the group of points on an elliptic curve over a finite field.
NR-final.pdf (335.6 Ko) Télécharger le fichier
hal-01550044 , version 1 (13-05-2020)
Thierry Mefenza, Damien Vergnaud. Polynomial Interpolation of the Naor-Reingold Pseudo-Random Function. Applicable Algebra in Engineering, Communication and Computing, 2017, 28 (3), pp.237-255. ⟨10.1007/s00200-016-0309-4⟩. ⟨hal-01550044⟩
124 Consultations
126 Téléchargements
