Resurrection of "Second Order" Models of Traffic Flow, SIAM Journal on Applied Mathematics, vol.60, issue.3, pp.916-938, 2000. ,
DOI : 10.1137/S0036139997332099
Flows on networks: recent results and perspectives, EMS Surveys in Mathematical Sciences, vol.1, issue.1, pp.47-111, 2014. ,
DOI : 10.4171/EMSS/2
ROAD NETWORKS WITH PHASE TRANSITIONS, Journal of Hyperbolic Differential Equations, vol.63, issue.01, pp.85-106, 2010. ,
DOI : 10.1016/S0191-2615(00)00050-3
URL : https://hal.archives-ouvertes.fr/inria-00534876
Priority-based riemann solver for traffic flow on networks, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01336823
Models for vehicular traffic on networks, 2016. ,
The Riemann problem at a junction for a phase transition traffic model, Discrete and Continuous Dynamical Systems, vol.37, issue.10, p.8, 2016. ,
DOI : 10.3934/dcds.2017225
Traffic Flow on a Road Network Using the Aw???Rascle Model, Communications in Partial Differential Equations, vol.4, issue.2, pp.31-243, 2006. ,
DOI : 10.1287/opre.4.1.42
Extensions and Amplifications of a Traffic Model of Aw and Rascle, SIAM Journal on Applied Mathematics, vol.62, issue.3, pp.729-745, 2001. ,
DOI : 10.1137/S0036139900378657
A second order model of road junctions in fluid models of traffic networks, Networks and Heterogeneous Media, pp.227-253, 2007. ,
Optimization criteria for modelling intersections of vehicular traffic flow, Networks and Heterogeneous Media, pp.275-294, 2006. ,
Coupling Conditions for a Class of Second-Order Models for Traffic Flow, SIAM Journal on Mathematical Analysis, vol.38, issue.2, pp.595-616, 2006. ,
DOI : 10.1137/05062617X
On the distribution schemes for determining flows through a merge, Transportation Research Part B: Methodological, vol.37, issue.6, pp.521-540, 2003. ,
DOI : 10.1016/S0191-2615(02)00026-7
Capacity drop and traffic control for a second order traffic model, accepted for publication in Networks and Heterogeneous Media, 2017. ,
An intersection model based on the GSOM model, Proceedings of the 17th World Congress, pp.7148-7153, 2008. ,
Mod??lisation du trafic autoroutier au second ordre, Modélisation du trafic autoroutier au second ordre, pp.1203-1206, 2008. ,
DOI : 10.1016/j.crma.2008.09.024
Generic second order traffic flow modelling, in Transportation and Traffic Theory, 2007. ,
On Kinematic Waves. II. A Theory of Traffic Flow on Long Crowded Roads, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.229, issue.1178, pp.317-345, 1955. ,
DOI : 10.1098/rspa.1955.0089
Second-order model and capacity drop at merge, Transportation Research Record, Journal of the Transportation Research Board, vol.5, issue.8, pp.2315-2340, 2012. ,
DOI : 10.3141/2315-03
Shock waves on the highway, Operations research, pp.42-51, 1956. ,
Balanced vehicular traffic at a bottleneck, Mathematical and Computer Modelling, vol.49, issue.3-4, pp.689-702, 2009. ,
DOI : 10.1016/j.mcm.2008.01.006
URL : http://doi.org/10.1016/j.mcm.2008.01.006
A non-equilibrium traffic model devoid of gas-like behavior, Transportation Research Part B: Methodological, vol.36, issue.3, pp.275-290, 2002. ,
