Abstract : Peer-to-peer conference is an interactive multi-users conferencing application that improves the issues of concentrated loading, single-point failure and expensive infrastructure cost for the traditional centralized conference model, according to the conference resource shared by each other. The benefit of non-centralized system can be achieved by using P2P-SIP. However, unlike the traditional centralized architecture, the conference resource is provided by each peer user. How to search the heterogeneous resource efficiently is a key point in the dynamic and distributed environment. Thus, we proposed a multi-constraint resource search algorithm for P2P-SIP conferencing services. In the full distributed environment, users can search a usable resource to reduce the call-setup time and save the conferencing cost according to the conferencing scale and the quality requirements.
https://hal.inria.fr/hal-01551334 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, June 30, 2017 - 10:35:48 AM Last modification on : Thursday, March 5, 2020 - 5:40:36 PM Long-term archiving on: : Monday, January 22, 2018 - 8:23:26 PM
Hui-Kai Su, Wen-Hsu Hsiao, Jian-Ting Pan, Chen-Hung Liao, Kim-Joan Chen, et al.. A Multi-constraint Resource Search Algorithm for P2P-SIP Conference Services. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.360-372, ⟨10.1007/978-3-642-35606-3_42⟩. ⟨hal-01551334⟩
