Abstract : A denial-of-service (DoS) / distributed-denial-of-service (DDoS) attack may result in rapid resource depletion along the attack path. For stepping-stone and masquerading techniques typically used in DoS/DDoS attacks such as internet protocol (IP) or Media Access Control (MAC) address spoofing, tracing the intrusion back to the true attacker becomes a challenging task for network security engineers. Although the Internet Engineer Task Force (IETF) has proposed an Internet Control Message Protocol (ICMP) based Traceback solution, it faces severe difficulties in practice in regard to justifying the interoperability of deployed routers as well as the correctness of Traceback with multiple attack paths. This research proposes a novel approach to embed the essence of a management information base (MIB) into iTrace messages, named MIB-ITrace-CP, in order to improve the accuracy and efficiency of the original ICMP-based Traceback. Through our implementations on a Testbed@TWISC platform, we validated our approach and demonstrated the feasibility of practical network forensics.
https://hal.inria.fr/hal-01551350 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, June 30, 2017 - 10:36:01 AM Last modification on : Thursday, March 5, 2020 - 5:40:38 PM Long-term archiving on: : Monday, January 22, 2018 - 9:11:11 PM
Bo-Chao Cheng, Guo-Tan Liao, Ching-Kai Lin, Shih-Chun Hsu, Ping-Hai Hsu, et al.. MIB-ITrace-CP: An Improvement of ICMP-Based Traceback Efficiency in Network Forensic Analysis. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.101-109, ⟨10.1007/978-3-642-35606-3_12⟩. ⟨hal-01551350⟩
