EaSync: A Transparent File Synchronization Service across Multiple Machines
In our daily life, people increasingly use multiple machines to do their daily work. As platform switching and file modification are so frequently that a way for file synchronization across multiple machines is required to make the files in synchronized. In this paper, we propose EaSync, a transparent file synchronization service across multiple machines. EaSync proposes several key technologies for file synchronization oriented service, including a timestamp based synchronization protocol, an enhanced deduplication algorithm DS-Dedup. We implement and evaluate the EaSync prototype system. As the result shown, EaSync outperforms other synchronization system in operation latency and other metrics.
Informatique [cs]
