Certificate-Based Encryption Scheme with General Access Structure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The protection of sensitive information is very important, but also a difficult task. It usually requires a centralised access policy management and control system. However, such solution is often not acceptable in the era of users’ mobility. In the paper we propose a certificate-based group-oriented encryption scheme with an effective secret sharing scheme based on general access structure. The special design of the scheme ensures that the shared secret (encryption key information), a collection of shareholders, and the access structure can be dynamically changed without the need to update the long-term keys and shares owned by shareholders. It is also possible to delegate the access rights to another member of the qualified subgroup or to a new entity from outside the current access structure.
978-3-642-33260-9_3_Chapter.pdf (172.99 Ko) Télécharger le fichier
hal-01551717 , version 1 (30-06-2017)
Paternité
Tomasz Hyla, Jerzy Pejaś. Certificate-Based Encryption Scheme with General Access Structure. 11th International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2012, Venice, Italy. pp.41-55, ⟨10.1007/978-3-642-33260-9_3⟩. ⟨hal-01551717⟩
156 Consultations
84 Téléchargements
