DockStar: a novel ILP-based integrative method for structural modeling of multimolecular protein complexes, Bioinformatics, vol.31, issue.17, pp.2801-2807, 2015. ,
DOI : 10.1093/bioinformatics/btv270
How cryo-EM is revolutionizing structural biology, Trends in Biochemical Sciences, vol.40, issue.1, pp.49-57, 2015. ,
DOI : 10.1016/j.tibs.2014.10.005
The revolution will not be crystallized: a new method sweeps through structural biology, Nature, vol.525, issue.7568, pp.172-174, 2015. ,
DOI : 10.1038/525172a
Multi-resolution contour-based fitting of macromolecular structures, Journal of Molecular Biology, vol.317, issue.3, pp.375-384, 2002. ,
DOI : 10.1006/jmbi.2002.5438
Single-Particle Cryo-EM at Crystallographic Resolution, Cell, vol.161, issue.3, pp.450-457, 2015. ,
DOI : 10.1016/j.cell.2015.03.049
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC4409662
Trust Region Methods, 2000. ,
DOI : 10.1137/1.9780898719857
Analysis of biological structure at the atomic and molecular level, Computer Physics Communications, vol.3, pp.137-138, 1972. ,
DOI : 10.1016/0010-4655(72)90121-X
Acta Cryst, pp.2069-2084, 2014. ,
The trust region subproblem and semidefinite programming*, Optimization Methods and Software, vol.10, issue.1, pp.41-67, 2004. ,
DOI : 10.1137/0325023
Modelling protein docking using shape complementarity, electrostatics and biochemical information 1 1Edited by J. Thornton, Journal of Molecular Biology, vol.272, issue.1, pp.106-120, 1997. ,
DOI : 10.1006/jmbi.1997.1203
ADP_EM: fast exhaustive multi-resolution docking for high-throughput coverage, Bioinformatics, vol.23, issue.4, pp.427-433, 2007. ,
DOI : 10.1093/bioinformatics/btl625
Quadratically constrained least squares and quadratic problems, Numerische Mathematik, vol.16, issue.115, pp.561-580, 1991. ,
DOI : 10.1007/BF01385796
Solving the Trust-Region Subproblem using the Lanczos Method, SIAM Journal on Optimization, vol.9, issue.2, pp.504-525, 1999. ,
DOI : 10.1137/S1052623497322735
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.119.2738
gEMfitter: A highly parallel FFT-based 3D density fitting tool with GPU texture memory acceleration, Journal of Structural Biology, vol.184, issue.2, pp.348-354, 2013. ,
DOI : 10.1016/j.jsb.2013.09.010
URL : https://hal.archives-ouvertes.fr/hal-00866871
iMODFIT: Efficient and robust flexible fitting based on vibrational analysis in internal coordinates, Journal of Structural Biology, vol.184, issue.2, pp.261-270, 2013. ,
DOI : 10.1016/j.jsb.2013.08.010
Computing a Trust Region Step, SIAM Journal on Scientific and Statistical Computing, vol.4, issue.3, pp.553-572, 1983. ,
DOI : 10.1137/0904038
Acta Cryst. A43, pp.645-653, 1987. ,
Acta Cryst, pp.157-163, 1994. ,
PEPSI-Dock: a detailed data-driven protein???protein interaction potential accelerated by polar Fourier correlation, Bioinformatics, vol.32, issue.17, pp.693-701, 2016. ,
DOI : 10.1093/bioinformatics/btw443
URL : https://hal.archives-ouvertes.fr/hal-01358645
Reconstruction of the chemotaxis receptor???kinase assembly, Nature Structural & Molecular Biology, vol.19, issue.5, p.400, 2006. ,
DOI : 10.1038/nsmb1085
Rapid determination of RMSDs corresponding to macromolecular rigid body motions, Journal of Computational Chemistry, vol.8, issue.12, pp.950-956, 2014. ,
DOI : 10.1371/journal.pone.0056645
URL : https://hal.archives-ouvertes.fr/hal-00952248
Allosteric signaling of ATP hydrolysis in GroEL???GroES complexes, Nature Structural & Molecular Biology, vol.26, issue.2, pp.147-152, 2006. ,
DOI : 10.1038/nsmb1046
High-order analytic translation matrix elements for real-space six-dimensional polar Fourier correlations, Journal of Applied Crystallography, vol.38, issue.5, pp.808-818, 2005. ,
DOI : 10.1107/S002188980502474X
URL : https://hal.archives-ouvertes.fr/inria-00434270
Protein docking using spherical polar Fourier correlations, Proteins: Structure, Function, and Genetics, vol.3, issue.2, pp.178-194, 2000. ,
DOI : 10.1107/S0567740882006153
URL : https://hal.archives-ouvertes.fr/inria-00434273
Accelerating and focusing protein-protein docking correlations using multi-dimensional rotational FFT generating functions, Bioinformatics, vol.24, issue.17, pp.1865-1873, 2008. ,
DOI : 10.1093/bioinformatics/btn334
URL : https://hal.archives-ouvertes.fr/inria-00434264
Particle finding in electron micrographs using a fast local correlation algorithm, Ultramicroscopy, vol.94, issue.3-4, pp.225-236, 2003. ,
DOI : 10.1016/S0304-3991(02)00333-9
Acta Cryst, pp.1341-1349, 2000. ,
Biomolecular pleiomorphism probed by spatial interpolation of coarse models, Bioinformatics, vol.24, issue.21, pp.2460-2466, 2008. ,
DOI : 10.1093/bioinformatics/btn461
Acta Cryst, pp.651-658, 2009. ,
Newton???s Method with a Model Trust Region Modification, SIAM Journal on Numerical Analysis, vol.19, issue.2, pp.409-426, 1982. ,
DOI : 10.1137/0719026
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.377.4773
Normal mode based flexible fitting of high-resolution structure into low-resolution experimental data from cryo-EM, Journal of Structural Biology, vol.147, issue.3, pp.315-326, 2004. ,
DOI : 10.1016/j.jsb.2004.03.002
A novel fast Fourier transform accelerated off-grid exhaustive search method for cryo-electron microscopy fitting, Journal of Applied Crystallography, vol.50, issue.4, pp.1036-1047, 2017. ,
DOI : 10.1107/S1600576717008172/po5090sup1.pdf
YUP.SCX: Coaxing atomic models into medium resolution electron density maps, Journal of Structural Biology, vol.163, issue.2, pp.163-174, 2008. ,
DOI : 10.1016/j.jsb.2008.05.001
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC3404851
EMAN2: An extensible image processing suite for electron microscopy, Journal of Structural Biology, vol.157, issue.1, pp.38-46, 2007. ,
DOI : 10.1016/j.jsb.2006.05.009
A multilevel algorithm for solving the trust-region subproblem, Optimization Methods and Software, vol.24, issue.2, pp.299-311, 2009. ,
DOI : 10.1080/10556780802571467
Protein Structure Fitting and Refinement Guided by Cryo-EM Density, Structure, vol.16, issue.2, pp.295-307, 2008. ,
DOI : 10.1016/j.str.2007.11.016
URL : http://doi.org/10.1016/j.str.2007.11.016
Quantitative Fitting of Atomic Models into Observed Densities Derived by Electron Microscopy, Journal of Structural Biology, vol.125, issue.2-3, pp.176-184, 1999. ,
DOI : 10.1006/jsbi.1998.4074
Using Situs for the integration of multi-resolution structures, Biophysical Reviews, vol.24, issue.1, pp.21-27, 2010. ,
DOI : 10.1007/s12551-009-0026-3
Acta Cryst, pp.344-351, 2012. ,
Modeling Tricks and Fitting Techniques for Multiresolution Structures, Structure, vol.9, issue.9, pp.779-788, 2001. ,
DOI : 10.1016/S0969-2126(01)00648-7
URL : http://doi.org/10.1016/s0969-2126(01)00648-7
A core-weighted fitting method for docking atomic structures into low-resolution maps: Application to cryo-electron microscopy, Journal of Structural Biology, vol.141, issue.1, pp.63-76, 2003. ,
DOI : 10.1016/S1047-8477(02)00570-1
Fast and sensitive rigid-body fitting into cryo-EM density maps with PowerFit, AIMS Biophysics, vol.2, issue.2, pp.73-87, 2015. ,
DOI : 10.3934/biophy.2015.2.73
FFT-based exhaustive search method 1047 ,
