Understanding the Impact of Emerging Non-Volatile Memories on High-Performance, IO-Intensive Computing, 2010 ACM/IEEE International Conference for High Performance Computing, Networking, Storage and Analysis, 2010. ,
DOI : 10.1109/SC.2010.56
Improving NAND flash based disk caches, 2008. ,
DOI : 10.1145/1394608.1382149
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.648.9699
Gordon: Using flash memory to build fast, power-efficient clusters for data-intensive applications, 2009. ,
A case for flash memory ssd in enterprise database applications, Proceedings of the 2008 ACM SIGMOD international conference on Management of data , SIGMOD '08, 2011. ,
DOI : 10.1145/1376616.1376723
Characterizing flash memory: Anomalies, observations,and applications, In: SC, 2009. ,
A superblock-based flash translation layer for NAND flash memory, Proceedings of the 6th ACM & IEEE International conference on Embedded software , EMSOFT '06, 2006. ,
DOI : 10.1145/1176887.1176911
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.160.2597
FAST: An Efficient Flash Translation Layer for Flash Memory, In: EUC Workshops, 2006. ,
DOI : 10.1007/11807964_88
Real-time garbage collection for flash-memory storage systems of real-time embedded systems, ACM Transactions on Embedded Computing Systems, vol.3, issue.4, 2004. ,
DOI : 10.1145/1027794.1027801
Deterministic Service Guarantees for NAND Flash using Partial Block Cleaning, Journal of Software, vol.4, issue.7, 2008. ,
DOI : 10.4304/jsw.4.7.728-737
A space-efficient flash translation layer for Compact Flash systems, In: TCE, 2002. ,
Scheduling garbage collection opportunistically to reduce worstcase I/O performance in SSDs, In: IWSSPS, 2009. ,
DOI : 10.1007/978-3-642-35170-9_9
Seagate: Serial ATA Native Command Queuing: An Exciting New Performance Feature for Serial ATA, Intel and Seagate, 2003. ,
Massive Arrays of Idle Disks For Storage Archives, ACM/IEEE SC 2002 Conference (SC'02), 2002. ,
DOI : 10.1109/SC.2002.10058
Efficient management of idleness in storage systems, ACM Transactions on Storage, vol.5, issue.2, 2009. ,
DOI : 10.1145/1534912.1534913
Idleness is not sloth, In: USENIX ATC, 1995. ,
Migrating server storage to SSDs, Proceedings of the fourth ACM european conference on Computer systems, EuroSys '09, 2009. ,
DOI : 10.1145/1519065.1519081
Incremental Merge Methods and Memory Systems Using the Same, 2006. ,
Everest: Scaling down peak loads through I/O offloading, In: EuroSys, 2008. ,
Write amplification analysis in flash-based solid state drives, Proceedings of SYSTOR 2009: The Israeli Experimental Systems Conference on, SYSTOR '09, 2009. ,
DOI : 10.1145/1534530.1534544
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.154.8668
