Abstract : Here we present three interactive artworks that showcase the abilities of active textured surfaces to enable new qualities of surface interactions. Giving the surfaces different sensing abilities, ways to act and behaviors, then allows us to explore emotional attributes and character perceived by an observer. The three designs reflect artworks emotional perception of the observer and the resulting effects on behavior. The surfaces sense it’s surrounding in terms of physical presence by proximity and emotional state based on facial expression. The surface can express its emotion with a change in movement and sound. The three surface designs explore further combinations of textile surfaces, sensors and reactive actuation to draw on the emotion of observers.
https://hal.inria.fr/hal-01556121 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, July 4, 2017 - 5:02:18 PM Last modification on : Wednesday, October 4, 2017 - 2:52:13 PM Long-term archiving on: : Friday, December 15, 2017 - 3:01:00 AM
Larissa Müller, Svenja Keune, Arne Bernin, Florian Vogt. Emotional Interaction with Surfaces - Works of Design and Computing. 11th International Confernece on Entertainment Computing (ICEC), Sep 2012, Bremen, Germany. pp.457-460, ⟨10.1007/978-3-642-33542-6_52⟩. ⟨hal-01556121⟩
