Serious Questions in Playful Questionnaires - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aneta Takhtamysheva
  • Fonction : Auteur
  • PersonId : 1011635
Jan Smeddinck
  • Fonction : Auteur
  • PersonId : 1011673
Conducting surveys is a time consuming and often expensive process. One of the main hurdles is motivating people to participate. The project presented herein proposes a playful approach, distributed via social network environments, where participants are intrinsically motivated to participate. A first evaluation showed an increased incentive to recommend friends to participate in the survey, as well as a preference of the playful approach to conducting surveys in general.
978-3-642-33542-6_50_Chapter.pdf (107.7 Ko) Télécharger le fichier
hal-01556164 , version 1 (04-07-2017)
Paternité
Aneta Takhtamysheva, Jan Smeddinck. Serious Questions in Playful Questionnaires. 11th International Confernece on Entertainment Computing (ICEC), Sep 2012, Bremen, Germany. pp.449-452, ⟨10.1007/978-3-642-33542-6_50⟩. ⟨hal-01556164⟩
103 Consultations
119 Téléchargements
