The Animation Loop Station: Near Real-Time Animation Production - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present the animation loop station, a near real-time animation production system. It brings the concept of loop stations or loopers commonly used for live music performances to the animation domain. Our system allows a single animator to build an animation layer by layer by capturing his own movement and building up complex motion through several passes or takes. In order not to interfere with capture and not break the performer’s flow, control commands are handled by a speech interface.
978-3-642-33542-6_55_Chapter.pdf (717.59 Ko) Télécharger le fichier
hal-01556167 , version 1 (04-07-2017)
Paternité
Benjamin Walther-Franks, Florian Biermann, Nikolaas Steenbergen, Rainer Malaka. The Animation Loop Station: Near Real-Time Animation Production. 11th International Confernece on Entertainment Computing (ICEC), Sep 2012, Bremen, Germany. pp.469-472, ⟨10.1007/978-3-642-33542-6_55⟩. ⟨hal-01556167⟩
98 Consultations
133 Téléchargements
