An 'empirical interpolation' method: application to efficient reduced-basis discretization of partial differential equations . Comptes Rendus de l'Académie des, Sciences Paris, vol.339, issue.9, pp.667-672, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00021702
Inverse Methods in Physical Oceanography, 1993. ,
DOI : 10.1017/CBO9780511600807
Numerical solution of saddle point problems, Acta Numerica, vol.14, issue.1, p.137, 2005. ,
DOI : 10.1017/S0962492904000212
Existence and Uniqueness for Four-Dimensional Variational Data Assimilation in Discrete Time, SIAM Journal on Applied Dynamical Systems, vol.16, issue.1, pp.361-374, 2017. ,
DOI : 10.1137/16M1068918
A reduced-order approach to four-dimensional variational data assimilation using proper orthogonal decomposition, International Journal for Numerical Methods in Fluids, vol.34, issue.10, pp.1571-1583, 2007. ,
DOI : 10.1002/fld.1365
A dual-weighted trust-region adaptive POD 4D-VAR applied to a finite-element shallow-water equations model, International Journal for Numerical Methods in Fluids, vol.523, issue.3, pp.520-541, 2011. ,
DOI : 10.1017/S0022112004002149
Dual formulation of four-dimensional variational assimilation, Quarterly Journal of the Royal Meteorological Society, vol.121, issue.544, pp.2449-2461, 1997. ,
DOI : 10.1034/j.1600-0870.1992.t01-3-00002.x
A strategy for operational implementation of 4D-Var, using an incremental approach, Quarterly Journal of the Royal Meteorological Society, vol.45, issue.519, pp.1367-1387, 1994. ,
DOI : 10.1034/j.1600-0870.1993.00011.x
A Dual-Weighted Approach to Order Reduction in 4DVAR Data Assimilation, Monthly Weather Review, vol.136, issue.3, pp.1026-1041, 2001. ,
DOI : 10.1175/2007MWR2102.1
Reduced Basis Method and A Posteriori Error Estimation for Parametrized Linear-Quadratic Optimal Control Problems, SIAM Journal on Scientific Computing, vol.32, issue.2, pp.997-1019, 2010. ,
DOI : 10.1137/090760453
Numerical Simulations with Data Assimilation Using an Adaptive POD Procedure, pp.165-172, 2010. ,
DOI : 10.1007/978-3-642-12535-5_18
Reduced order modeling based on POD of a parabolized Navier???Stokes equations model II: Trust region POD 4D VAR data assimilation, Computers & Mathematics with Applications, vol.65, issue.3, pp.380-394, 2013. ,
DOI : 10.1016/j.camwa.2012.06.001
Convex Analysis and Variational Problems. Studies in mathematics and its applications, 1976. ,
DOI : 10.1137/1.9781611971088
Regularization of Inverse Problems, 1996. ,
Theory and Practice of Finite Elements, Applied Mathematical Sciences, vol.159, 2010. ,
DOI : 10.1007/978-1-4757-4355-5
Optimal control of distributed systems, Theory and applications, vol.187, 2000. ,
Certified Reduced Basis Methods for Parametrized Saddle Point Problems, SIAM Journal on Scientific Computing, vol.34, issue.5, pp.2812-2836, 2012. ,
DOI : 10.1137/110854084
Efficient reduced-basis treatment of nonaffine and nonlinear partial differential equations, ESAIM: Mathematical Modelling and Numerical Analysis, vol.49, issue.3, pp.575-605, 2007. ,
DOI : 10.1109/8.929635
URL : https://hal.archives-ouvertes.fr/hal-00112154
error bounds for reduced-basis approximations of parametrized parabolic partial differential equations, ESAIM: Mathematical Modelling and Numerical Analysis, vol.8, issue.1, pp.157-181, 2005. ,
DOI : 10.1051/cocv:2002041
Reduction of the uncertainties in the water level-discharge relation of a 1D hydraulic model in the context of operational flood forecasting, Journal of Hydrology, vol.532, pp.52-64, 2016. ,
DOI : 10.1016/j.jhydrol.2015.11.023
URL : https://hal.archives-ouvertes.fr/hal-01244241
Optimization with PDE Constraints, Mathematical Modelling: Theory and Applications, vol.23, 2009. ,
Efficiency of reduced-order, time-dependent adjoint data assimilation approaches, Journal of Oceanography, vol.124, issue.C9, pp.539-550, 1007. ,
DOI : 10.1017/CBO9780511629570
A successive constraint linear optimization method for lower bounds of parametric coercivity and inf???sup stability constants, Comptes Rendus Mathematique, vol.345, issue.8, pp.473-478, 2007. ,
DOI : 10.1016/j.crma.2007.09.019
Unified Notation for Data Assimilation : Operational, Sequential and Variational (gtSpecial IssueltData Assimilation in Meteology and Oceanography: Theory and Practice), Journal of the Meteorological Society of Japan. Ser. II, vol.75, issue.1B, pp.181-189, 1997. ,
DOI : 10.2151/jmsj1965.75.1B_181
Certified reduced basis methods for parametrized pde-constrained optimization problems, 2017. ,
A certified reduced basis method for parametrized elliptic optimal control problems, ESAIM: Control, Optimisation and Calculus of Variations, vol.20, issue.2, pp.416-441, 2013. ,
DOI : 10.1002/fld.867
A posteriori error estimation for reduced order solutions of parametrized parabolic optimal control problems, pp.2-48, 2014. ,
Certified Reduced Basis Methods for Parametrized Elliptic Optimal Control Problems with Distributed Controls, Journal of Scientific Computing, vol.8, issue.1, 2017. ,
Source reconstruction of an accidental radionuclide release at European scale, Quarterly Journal of the Royal Meteorological Society, vol.33, issue.623, pp.529-544, 2007. ,
DOI : 10.1007/978-1-4615-3720-5_35
URL : https://hal.archives-ouvertes.fr/inria-00633475
Data assimilation for short-range dispersion of radionuclides: An application to wind tunnel data, Atmospheric Environment, vol.40, issue.38, pp.7267-7279, 2006. ,
DOI : 10.1016/j.atmosenv.2006.06.043
URL : https://hal.archives-ouvertes.fr/hal-00650966
Data Assimilation, 2015. ,
DOI : 10.1007/978-3-319-20325-6
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.109, issue.2, pp.97-110, 1986. ,
DOI : 10.1007/978-3-642-65024-6
A Global Three-Dimensional Multivariate Statistical Interpolation Scheme, 109{$$}0701:AGTDMS{$$}2.0.CO, pp.701-721, 1981. ,
DOI : 10.1175/1520-0493(1981)109<0701:AGTDMS>2.0.CO;2
Analysis methods for numerical weather prediction, Quarterly Journal of the Royal Meteorological Society, vol.108, issue.474, pp.1177-1194, 1986. ,
DOI : 10.1175/1520-0493(1970)098<0875:SBFINV>2.3.CO;2
The Princeton Companion to Applied Mathematics, chap. Numerical Weather Prediction, pp.705-712, 2015. ,
A general multipurpose interpolation procedure: the magic points, Communications on Pure and Applied Analysis, vol.8, issue.1, pp.383-404, 2007. ,
DOI : 10.3934/cpaa.2009.8.383
URL : https://hal.archives-ouvertes.fr/hal-00174797
A parameterized-background data-weak approach to variational data assimilation: formulation, analysis, and application to acoustics, International Journal for Numerical Methods in Engineering, vol.200, issue.Series D, pp.933-965, 2015. ,
DOI : 10.1016/j.cma.2011.02.019
PBDW State Estimation: Noisy Observations; Configuration-Adaptive Background Spaces; Physical Interpretations, ESAIM: Proceedings and Surveys, vol.50, pp.144-168, 2015. ,
DOI : 10.1051/proc/201550008
Solvability and numerical algorithms for a class of variational data assimilation problems. ESAIM, Control Optim, Calc. Var, vol.8, pp.873-883, 2002. ,
Reduced Basis Method for Parametrized Elliptic Optimal Control Problems, SIAM Journal on Scientific Computing, vol.35, issue.5, pp.2316-2340, 2013. ,
DOI : 10.1137/120894737
The mathematical theory of optimal processes; translated from the Russian by, 1964. ,
Reliable real-time solution of parametrized partial differential equations: Reduced-basis output bound methods, J. Fluid. Eng, vol.124, issue.1, pp.70-80, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00798326
A Nonstandard Approach to a Data Assimilation Problem and Tychonov Regularization Revisited, SIAM Journal on Control and Optimization, vol.48, issue.2, pp.1089-1111, 2009. ,
DOI : 10.1137/060670961
URL : https://hal.archives-ouvertes.fr/hal-00679716
Robust Data Assimilation Using $L_1$ and Huber Norms, SIAM Journal on Scientific Computing, vol.39, issue.3, pp.548-570, 2017. ,
DOI : 10.1137/15M1045910
Probabilistic Forecasting and Bayesian Data Assimilation, 2015. ,
DOI : 10.1017/CBO9781107706804
A reduced-order strategy for 4D-Var data assimilation, Journal of Marine Systems, vol.57, issue.1-2, pp.70-82, 2005. ,
DOI : 10.1016/j.jmarsys.2005.04.003
URL : https://hal.archives-ouvertes.fr/hal-00230165
Reduced Basis Approximation and a Posteriori Error Estimation for Affinely Parametrized Elliptic Coercive Partial Differential Equations, Archives of Computational Methods in Engineering, vol.40, issue.11, pp.229-275, 2008. ,
DOI : 10.1016/j.crma.2003.09.023
URL : https://hal.archives-ouvertes.fr/hal-01722593
SOME BASIC FORMALISMS IN NUMERICAL VARIATIONAL ANALYSIS, SBFINV$ $2.3.CO, pp.875-883, 1970. ,
All-at-once solution of time-dependent Stokes control, Journal of Computational Physics, vol.232, issue.1, pp.498-515, 2013. ,
DOI : 10.1016/j.jcp.2012.08.039
Accounting for an imperfect model in 4D-Var, Quarterly Journal of the Royal Meteorological Society, vol.121, issue.621, pp.2483-2504, 2006. ,
POD a-posteriori error estimates for linear-quadratic optimal control problems, Computational Optimization and Applications, vol.8, issue.1, pp.83-115, 1007. ,
Model-Reduced Variational Data Assimilation, Monthly Weather Review, vol.134, issue.10, pp.2888-2899, 2006. ,
DOI : 10.1175/MWR3209.1
Error Estimation for Reduced-Basis Approximation of Parametrized Elliptic Coercive Partial Differential Equations: ???Convex Inverse??? Bound Conditioners, ESAIM: Control, Optimisation and Calculus of Variations, vol.7, pp.1007-1028, 2002. ,
DOI : 10.1137/0907034
