Semantic Proximity Between Queries and the Empty Answer Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
—This paper proposes an approach aimed at obviating empty answers for a family of conjunctive queries involving Boolean or fuzzy value constraints. Contrary to the approaches based on a relaxation of the predicates involved in the query, the principle suggested here consists in replacing the query by another one similar which has been processed previously and whose answer is known to be non-empty. This technique thus avoids the combinatory induced by classical relaxation-based approaches.
EUSFLAT09Short-v2.pdf (232.63 Ko) Télécharger le fichier
hal-01556456 , version 1 (05-07-2017)
  • HAL Id : hal-01556456 , version 1
P Bosc, C Brando, H Hadjali, Hélène Jaudoin, O Pivert. Semantic Proximity Between Queries and the Empty Answer Problem. IFSA-EUSFLAT, Jul 2009, Lisbon, Portugal. ⟨hal-01556456⟩
351 Consultations
58 Téléchargements
