New interface
Conference papers
Enumerating Cyclic Orientations of a Graph
Abstract : Acyclic and cyclic orientations of an undirected graph have been widely studied for their importance: an orientation is acyclic if it assigns a direction to each edge so as to obtain a directed acyclic graph (DAG) with the same vertex set; it is cyclic otherwise. As far as we know, only the enumeration of acyclic orientations has been addressed in the literature. In this paper, we pose the problem of efficiently enumerating all the cyclic orientations of an undirected connected graph with n ver-tices and m edges, observing that it cannot be solved using algorithmic techniques previously employed for enumerating acyclic orientations. We show that the problem is of independent interest from both combinato-rial and algorithmic points of view, and that each cyclic orientation can be listed with˜Owith˜ with˜O(m) delay time. Space usage is O(m) with an additional setup cost of O(n 2) time before the enumeration begins, or O(mn) with a setup cost of˜Oof˜ of˜O(m) time.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01557026
Contributor : Marie-France Sagot Connect in order to contact the contributor
Submitted on : Wednesday, July 5, 2017 - 5:00:03 PM
Last modification on : Tuesday, May 17, 2022 - 2:50:02 PM
Long-term archiving on: : Tuesday, January 23, 2018 - 9:26:43 PM
File
conte2016.pdf
Identifiers
Collections
Citation
Alessio Conte, Roberto Grossi, Andrea Marino, Romeo Rizzi. Enumerating Cyclic Orientations of a Graph. 26th International Workshop on Combinatorial Algorithms, IWOCA 2015, 2016, Verona, Italy. pp.88 - 99, ⟨10.1007/978-3-319-29516-9_8⟩. ⟨hal-01557026⟩
Share
Metrics
Record views
66
Files downloads
142
