Measurement of grain moisture content using microwave attenuation at 10.5 GHz and moisture density[J]. Instrumentation and Measurement, IEEE Transactions on, vol.1, issue.151, pp.72-77 ,
Study on microwave measurement for grain moisture content in grain depot. omputer Engineering and Applications, pp.46-239, 2010. ,
Detector testing of grain moisture based on resistance capacitance method, China Metrology, issue.10, pp.52-56, 2002. ,
Study on Grain's Moisture Detector Based on Capacitive Sensor Capacitance sensor for nondestructive measurement of moisture content in NUTS and grain, Journal of Agricultural Mechanization Research IEEE Transactions, issue.65, pp.122-123, 2005. ,
Fringing Field Capacitance Sensor for Measuring the Moisture Content of Agricultural Commodities, IEEE Sensors Journal, vol.8, issue.3, pp.240-247, 2008. ,
DOI : 10.1109/JSEN.2007.913140
New density-independent calibration function for microwave sensing of moisture content in particulate materials Instrumentation and Measurement, IEEE Transactions on, issue.3, pp.47-613, 1998. ,
Statistical relationship between apparent dielectric constant and water content in porous media, pp.47-50, 1985. ,
Characteristic impedance of unbalanced TDR probes Instrumentation and Measurement, IEEE Transactions, issue.3, pp.51-532, 2002. ,
Improved field probes for soil water content and electrical conductivity measurement using time domain reflectometry, Water Resources Research, issue.11, pp.25-2367, 1989. ,
Theoretical and experimental approach to calculation of the impedance of soil probe, ACTA PEDOLOGICA SINICA, issue.1, pp.120-126, 2002. ,
On the transfer function mathematical model and its experimental study for the measurement of soil water content system, Journal of Agricultural Mechanization Research, vol.2002, issue.2, pp.24-26 ,
Study of grain boundary polarization by two-probe and four-probe impedance spectroscopy, Solid State Ionics, pp.115-125, 1999. ,
