Application Feasibility Analysis of Precision Agriculture in Equipment for Controlled Traffic Farming System: A Review
Equipment includes planter, field management equipment and harvester for controlled traffic farming system is elaborated in the paper. And the analysis results shows that main problems of equipment for controlled traffic farming system contains poor ability to navigate, uneven and bent wheel lanes. To solve the problem, the thought that precision agriculture is introduced into equipment for controlled traffic farming system is put forward. For this purpose, the key technology of precision agriculture is introduced, and the feasibility of combination of precision agriculture and controlled traffic farming system is discussed, which provides theoretical support for the development of equipment for controlled traffic farming system.
Informatique [cs]
