Ramaswamy Chandramouli.Role-Based Access Control, 2007. ,
Role-Based Access Control Models, IEEE Computer, vol.29, pp.38-47, 1996. ,
UML-Based Representation of Role-Based Access Control, IEEE 9th International Workshops on Enabling Technologies: Infrastructure for Collaborative Enterprises (WET ICE'00), pp.195-200, 2000. ,
Research on Role-Based Access Control and ITS Application in Court System, 2003. ,
The Application of Role-Based Access Control Technology in Union Equipment Management Center System, 2007. ,
Research of Permission Management Based on Role and Discretionary Access Control, Software Guide, pp.160-162, 2010. ,
Research and application of Role-Based Access Control in Privilege Management, Microcomputer Information, pp.9-329, 2006. ,
RBAC Based Classified Application System Access Control Method Design[A].The Paper Collection of 2012 MIS / S & A Academic Conference, pp.182-185 ,
Specify RBAC Constraints Using Object Constraint Language, Computer Engineering and Applications, vol.39109, issue.21, pp.100-102, 2003. ,
Research of Extension of Static Constraints Mechanism in RBAC Model, Journal of Beijing University of Posts and elecommunications, issue.3, pp.31123-127, 2008. ,
Role-Based Authorization Constraint with Time Character[ J], Journal of Software, vol.13, issue.8, pp.1521-1527, 2002. ,
Web Applications of Role-Based Access Control, 2002. ,
Design of extended role-based access control model and its implementation, Computer Engineering and Design, vol.29, issue.18, pp.4178-4721, 2008. ,
