Design of Integrated Low-Power Irrigation Monitoring Terminal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to realize low-cost automatic control of field irrigation and water metering, an integrated low-power irrigation monitoring terminal based on wireless data communication was designed. Powered by battery or solar, the terminal could acquire and store data of sensors and water meters in real-time. Taking valve as control object, the terminal can provide safe irrigation strategy based on multiple control logic, such as data overrun, time and manual operation. The detection of fault on-site and reasonable judgment of irrigation can be carried out by using self-check function, querying of local data and remote data transmission based on GPRS and Modbus Protocol. Experimental results showed that the terminal could work stably, and control irrigation water usage accurately with low power cost.
434296_1_En_25_Chapter.pdf (572.22 Ko) Télécharger le fichier
hal-01557813 , version 1 (06-07-2017)
Paternité
Hongwu Tian, Mingfei Wang, Jinlei Li. Design of Integrated Low-Power Irrigation Monitoring Terminal. 9th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2015, Beijing, China. pp.255-265, ⟨10.1007/978-3-319-48357-3_25⟩. ⟨hal-01557813⟩
52 Consultations
112 Téléchargements
