Aquatic Animal Disease Diagnosis System Based on Android
In recent years, as long as the rapid development of aquaculture, the occurrence of aquatic animal diseases increase year by year, which restrict the sustained, steady, and healthy development of aquaculture. So the rapid diagnosis of aquatic animal disease is particularly important for their prevention and control. In the present work, an Android-based aquatic animal disease diagnostic system has been developed in order to provide more convenient and effective aquatic animal disease diagnostic services to ordinary farmers. The designed system includes the part of the man-machine interface (user interface, expert interface), inference engine, the case base, knowledge base and so on. Interactive interface is a visual display interface. Inference engine was written in the Java programming language. Case base and knowledge base were created using SQLite. The results show that ordinary farmers can easily use this system to realize the convenient, fast, and accurate access to the findings of disease diagnosis and prevention measures as well as aquaculture expert can add, delete, modify, view the case base and knowledge base at any time.
Informatique [cs]
