Study on pneumatic precision seeder in China Agricultural Equipment & Vehicle Engineering, pp.17-21, 2013. ,
Experimental study on pneumatic precision seed metering mechanism of field breeding planter, Transactions of the Chinese Society of Agricultural Engineering (Transactions of the CSAE), pp.28-59 ,
Design and experiment on electronic control system for plot seeder, Transactions of the CSAE, issue.5, pp.27-122, 2011. ,
The survey and the prospect in china of the pneumatic drills, Chinese Agricultural Mechanization, pp.70-72, 2008. ,
Improved application of stepless speed control technology in seeding machine, Computer Systems & Applications, issue.6, pp.23250-254, 2014. ,
Performance detection of precision seed-metering device based on single chip microprocessor, Science Technology and Engineering, issue.12, pp.338329-8302, 2011. ,
Design of intelligent control system for tworow precise seeding of wheat, Transactions of the CSAE, vol.2012, issue.28, pp.5134-139 ,
Design and experiment of electro-hydraulic proportional control hill distance system of precision rice hill-drop drilling machine for dry land, Transactions of the CSAE, vol.2015, issue.9, pp.31-56 ,
Research on the planting drive system based on a tractor frontwheel speed, 2009. ,
Improved Design and experiment on pickup finger precision seed metering device, J]. Transactions of the CSAM, vol.2015, p.9 ,
Experimental study on pressure of air-blowing precision seed-metering device[J]. Transactions of the CSAE, pp.27-45, 2011. ,
Simulation analysis of working process and performance of cell wheel metering device, Transactions of the CSAM, issue.12, pp.14283-87, 2011. ,
Design and experiment of pneumatic maize precision seed-metering device with combined holes, J]. Transactions of the CSAE, vol.2014, issue.5, pp.30-40 ,
Design and experiment of collocated- copying and semi-low-height planting-unit for corn precision seeder, J].Transactions of the CSAE, vol.2012, issue.S2, pp.28-46 ,
Tong Ling?Effect of planting density on root-shoot growth and water utilization efficiency of seed corn, Journal of Drainage and Irrigation Machinery Engineering, issue.12, pp.321091-1097, 2014. ,
Effects of varieties and planting density on plant traits and water consumption characteristics of spring maize, J]. Transactions of the CSAE, vol.2012, issue.11, pp.28-125 ,
