Making best use of model evaluations to compute sensitivity indices, Computer Physics Communications, vol.145, pp.280-297, 2002. ,
, Sensitivity Analysis in Practice, vol.425, 2004.
Sobol', Sensitivity analysis for nonlinear mathematical models, Mathematical Modeling and Computational Experiment, vol.1, pp.407-414, 1993. ,
Variance components and generalized sobol'indices, SIAM/ASA Journal on Uncertainty Quantification, vol.1, issue.1, pp.19-41, 2013. ,
On the use of variance reducing multipliers in monte carlo computations of a global sensitivity index, Comput. Phys. Commun, vol.117, issue.1, pp.52-61, 1999. ,
Estimating sobol sensitivity indices using correlations, Environ. Model. Softw, vol.37, pp.157-166, 2012. ,
Asymptotic normality and efficiency of two sobol index estimators, ESAIM: Probability and Statistics, vol.18, pp.342-364, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00665048
Evaluating prediction uncertainty, pp.1-79, 1995. ,
Sampling plans based on balanced incomplete block designs for evaluating the importance of computer model inputs, Journal of Statistical Planning and Inference, vol.136, issue.9, pp.3203-3220, 2006. ,
Using orthogonal arrays in the sensitivity analysis of computer models, Technometrics, vol.50, issue.2, pp.205-215, 2008. ,
Comparison of some efficient methods to evaluate the main effect of computer model factors, Journal of Statistical 450 Computation and Simulation, vol.78, issue.2, pp.167-178, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01093033
A randomized orthogonal array-based procedure for the estimation of first-and second-order sobol'indices, Journal of Statistical Computation and Simulation, vol.85, issue.7, pp.1358-1381, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00743964
ANOVA-like tech455 niques and the use of bootstrap, Sensitivity measures, vol.58, pp.99-120, 1997. ,
A class of statistics with asymptotically normal distributions, Annals of Mathematical Statistics, vol.19, pp.293-325, 1948. ,
Lattice sampling revisited: Monte carlo variance of means over 460 randomized orthogonal arrays, The Annals of Statistics, pp.930-945, 1994. ,
Uncertainty and sensitivity analysis for crop models, Working with Dynamic Crop Models: Evaluation, Analysis, Parameterization, and Applications, pp.55-99, 2006. ,
Variance-based sensitivity analysis: Theory and estimation algorithms, Handbook of Uncertainty Quantification, pp.1-23, 2016. ,
Iterative construction of replicated designs based on 470 sobol'sequences, Comptes Rendus Mathematique, vol.355, issue.1, pp.10-14, 2017. ,
On latin and hyper-graeco-latin cubes and hyper cubes, Current Science, vol.11, issue.3, pp.98-99, 1942. ,
Hypercubes of strength d leading to confounded designs in factorial experiments, Bull. Calcutta Math. Soc, vol.38, issue.3, pp.67-78, 1946. ,
Orthogonal arrays of strength two and three, The Annals of Mathematical Statistics, pp.508-524, 1952. ,
Replication procedure for grouped sobol'indices estimation in dependent uncertainty spaces, Information and Inference, p.10, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01045034
Orthogonal arrays, 1999. ,
Nonparametric standard errors and confidence intervals, Canadian Journal of Statistics, vol.9, issue.2, pp.139-158, 1981. ,
Bootstrap methods for standard errors, confidence intervals, and other measures of statistical accuracy, Statistical science, vol.1, issue.1, pp.54-75, 1986. ,
An importance quantification technique in uncertainty analysis for computer models, Uncertainty Modeling and Analy490 sis, 1990. Proceedings., First International Symposium on, pp.398-403, 1990. ,
Implementation and tests of lowdiscrepancy sequences, ACM Trans. Model. Comput. Simul, vol.2, issue.3, pp.195-213, 1992. ,
Quasi-monte carlo integration, J. Comput. Phys, vol.122, issue.2, pp.218-230, 1995. ,
Additive regression and other nonparametric models, The Annals of, Statistics, vol.13, issue.2, pp.689-705, 1985. ,
gam: Generalized Additive Models, r package version 1, pp.14-18 ,
